Yes mate its connected up with a home plug
Got Kryptview box today but cant get channels
is it possible to connect your box to your router using an ethernet cable and connect to your cable feed temperally just for testing?Comment
i am trying to estasblish wether your homeplugs are working correctly.
if you have put newest firmware on box, then message should read "update not req"
if you have an older version firmware then message should read "update in progress" and will automatically update your firmware to latest version..
if you get anything, that means you are not connecting to server...
keep watching see if box updates or you get an error message.....Comment
if your box says searching for updates, it means that it cannot connect to the server...
if its possible,
connect your box via ethernet cable to router,
hook up to tv and hit s/w update again.
note that you do not need your cable feed connected for this....Comment
hi all.iv got same prob as sum on hear.system info 09/09/2010 software version pv3.6.00 i get list . telepest. network. tick. ok net ID.go to 41016 liverpool. select press ok.TV CHANNELS OK. signal strenght 77/88...i get freview 1/2/3/4/5
then scrambled or no video and the box locks at channel 0124.will not switch of or change to exit or menu switch of at wall. back the same.can get virgin test 104.and on demand previews. 1/2/3/4/5 freeview.
i have got no spliters and erthinet to modem. is it the 780 box? i only pay broadband internet. no tv no phone.
ps i get a IPaddres conflict also on my w/less roter/computer. thanksComment
