Got Kryptview box today but cant get channels
that is probably your problem
the homeplugs work by using the ring mains
ie all your downstairs sockets are wired one after another...
your upstairs sockets will probably be on a diffrent circuit..
therefore no connection.....
i think
quote:
Would HomePlugs work on different mains circuits (rings) in my house ?
There is mis-information about this subject on the web - the answer is Yes - limitations are as follows - the rings or circuits (such as upstairs and downstairs) mains must be on the same fuse box / consumer box. - if you have other configurations just call and we will do our best to advise.
well if you got lappy plug one homeplug into router and other one in a socket beside box and run ethernet lead to lappy switching wireless conection off and see what ip you get or if it connects to net
yesLast edited by jumpinjo; 23 September, 2010, 12:53.Comment
never had any probs and no loads using up/downComment
when you scan, thebox automatically sorts the channels into cats
if you want to look for a channel alphabetically.
press the white button.
then select the first letter of the channel yyou are looking for....Comment
your help was much appreciated
