True, at times the pic can be nearly as good as hd. Its great! Server problems have eased alot recently.
channel frezzing
Walsall?
why is there no Walsall area to pick up on channel scan the only nearest is wolverhampton but shouldnt Walsall have its own? also it would have been better if it had brutforce like dreambox
that should be ok.
1. make sure all connections are tight.
2. watch this
YouTube - Setting up the Kryptview KV780 Cable Receiver
3. post your location
hopefully someone will post back your correct net id/provider...
got to go now.. best of luck.....
has anyone else had any glitching problems tonight?
been watching movie channels and mine has been glitching every few min, my signal was 60 but i brought a booster its taken it up to 82 but it still glitching! im using an edimax 3g router, would the glitching because of the dongle?? i even tryed using a different coax lead tonight but no lookComment
RE: intermitant problems with reception, blocky reception or losing certain channels (but not all) and even lack of tp's?
Re-make all the ends of the cable connections. Properly! (using SAT connectors & cable, NOT co-axil)
FIXED
