KW A750 iConnector Firmware
  • cactikid
    • 12017
    #31
    sounds as if not connected to the net,is your lan cable correct
    as i have heard some dont,can you try in a different location,remember to reboot router and box by powering off at back for a short while then on.
    • akhlaq768
      • 196
      #32
      i have tried a different lan cable and still no luck. afte re scanning the box it is fine, and once i power up the i connecter my front display of the box immediately comes up with a fail message. this keeps flashing up every 2 seconds or so. this is the point in which i am stuck as the a750 is not doing the major update that it should.
      • smirnoff_rules
        • 8603
        #33
        r u using the null cable that came with the i-conn
        • akhlaq768
          • 196
          #34
          yes i am using this
          • smirnoff_rules
            • 8603
            #35
            Originally posted by akhlaq768
            yes i am using this
            wonder if its damaged ?
            • akhlaq768
              • 196
              #36
              how do i check this?
              • smirnoff_rules
                • 8603
                #37
                u would have to use a mulitmeter . best to get another from maplins . but lm only guessing m8 at the minute .. it should be working
                • akhlaq768
                  • 196
                  #38
                  just tried another cable and still no luck, i have re flashed the box about 5 times, and still no luck as soon as i connect my i connector my box just keeps flashing FAIL and the 1 of the 2 LED lights starts to flash the other remains constant.
                  • akhlaq768
                    • 196
                    #39
                    just wondering is it because im using a modded modem? ive got a motorolla Sb5101e using haxoware!
                    is thats why my iconnector isn't working
                    • smirnoff_rules
                      • 8603
                      #40
                      l have searched google for the last 20 minutes and the only box that says fail is the kv700 there isnt a thread anywhere that has had fail on the front of an 750 ? strange that
                      • akhlaq768
                        • 196
                        #41
                        thanks for searching but i definatley have the black A750.
                        Do you think its a issue with the IP address on the modem? or something?
                        • DW190
                          #42
                          Are you using a router or straight into the modem?
                          • akhlaq768
                            • 196
                            #43
                            i am using a router however have tried plugging it straight into the modem.
                            • DW190
                              #44
                              Looking at the rest of the thread it looks like its updated itself when first used as you mentioned Succ.
                              First make sure your terestrial channels are working: BBC1, 2, ITV, C4 & Five.
                              With all devices powedred on and the box on Sky Sports 1 start with the Modem by powering it off for 10 secs then back on, wait till lights are stable then do the same with the router, then the Iconnector, then the box.
                              • akhlaq768
                                • 196
                                #45
                                All terestrial channels are working perfectly.
                                will power down all devices and power up... will keep you updated
