thanks for the help so far - that link was bang on and i now have a downloader :0)
but i now seem to have the same problem as i have seen on this thread time and time again which is " the downloading is not requested" I have tried 3 diferent ports 3/4/and 7 and changed it in the loader each time - getting a step closer but still no goal
does anyone know if the latest kryptview release will fix the loss of channels???
worked for mine - just followed the instructions provided in this thread and ime up and running
be sure to read all posts on this thread because the answers are all there
cheers for that but i had the 29/12/08 fix on and found that some channels were missing although there was no freezing with that fix. Tried re-scanning but no good. Will see tonight if it's fixed
hope it has all worked for you as it has for me m8
i would advise that you check other treads as i have done to sort out yur channels cuz it seems like you have done the hard work and it is just a case of reseting your tp's for your area - i feel sure someone will be able to talk you through that
Good luck and u are in the right place for this type of help
I have the same problem, i've been told it's because i am using Vista?
just keep going at it and reading the info in this thread i feel sure you will crack it - it cant be vista because i am using it so it has to be something simple like i was doing ( i missed the "press red button twice statement" and was only pressing it once) something as simple as that after 4 hrs of trying can create a host of problems. have a beer and read this thread again and you may just spot something you have missed the first time round.
Good luck and i hope you solve it the ppl here are always willing to help.
I have been getting the download not requested message for ages now, and need help desperately.
I have changed the settings in the Device Manage for my com ports, can anyone verify all the setting for the com port, I have tried several, but some say (in use) and does not recommend I use them or should I try them too?
Io have tried every set of instructions available for the KV box, and tried all downloads, none of which help.
I have the loader, instructions and have extracted the bin* file from the downloaded flash.
