lost channels overnight
  • pete666
    • Oct 2010
    • 64
    got up today lost 101 to 107 anyone no why ? did a rescan still not there am in kirklees nthell .net id 0001
  • DW190
    If the box has been in standby (powerscan mode) over night its possible that there has been some maintenance on a particular transponder and it has scanned a blank. Leave in standby overnight again and they will probably come back. Scanning should bring them back as long as any maintenance is complete.
    • pete666
      • Oct 2010
      • 64
      thanks i,ll try to rescan now and see
      • pete666
        • Oct 2010
        • 64
        done another scan , still same channels missing
        • barrowmanandrew
          • 3427
          are you defo on the correct net id?
          • pete666
            • Oct 2010
            • 64
            how i check it i know net id is 0001 where i look in bx for it
            • barrowmanandrew
              • 3427
              make sure you are acanning properly...
              1 do a factory reset
              2 select automatic scan
              3 change provider to (your provider)
              4 change channel type to "networked"
              5 start scan (green buton i think)
              6 after a few mins a list of tp's should appear
              7 chose you net id
              8 box should now scan and store all channels.
              if there are still channels missing, then you may have a weak signal.
              [ame="http://www.youtube.com/watch?v=LsEvfBnceiM"]YouTube - Setting up the Kryptview KV780 Cable Receiver[/ame]
              • pete666
                • Oct 2010
                • 64
                let you know doing one now thanks again
                • pete666
                  • Oct 2010
                  • 64
                  all back thanks for your help
