kv750
  • guppyabby
    • 232
    kv750
    hi,can anybody confirm if kv 750 is down or is it the sever as mine gone dead saying scrambbled or no signal,this happens alot.tried swichting on & off but no luck ,help will be appriciated.
  • janobi
    • 1624
    Servers are fine, its your setup that is causing problems.
    • guppyabby
      • 232
      thanx for your quick reply, iv connected to wireless router then to iconn then in to receiver,still used to work although i had to switch on off many times to clear the signal,if this is wrong can you please advice me how it should be done tanx 4 your help.
      • DW190
        If its bad or no signal it sounds like your cable feed to your box. Could be a poor connected screw end or loose wire.
        Try BBC 1, if that says bad or no signal its deffo the cable feed.
        • guppyabby
          • 232
          him8 checked all cables ok but iv got april software could that b the problem,does it need updating.
          • barrowmanandrew
            • 3427
            go to:
            menu
            installation
            s/w update
            and the box will automatically update...
            • guppyabby
              • 232
              iv tried that mate but getting error message.
              • EAMO 2
                • 1201
                Looks like your box is not connecting to internet. Reboot router
                then reboot box. Otherwise go to network setup in menu. Select
                UK and Auto-connect.
                • guppyabby
                  • 232
                  if im not connected to internet how comes its working most of the day,the signal strengthat the moment is top bar 56 bott.55
                  • guppyabby
                    • 232
                    furthe more m8 iv tried what you said set up menue= but cant get uk .auto connect in the menue bar,any idea,thanx
                    • EAMO 2
                      • 1201
                      Sorry for earlier post, I may be confusing KV with SVU or Ddigital. I don't have KV to check menu, but if you reboot router, then power-up i-connect, then power-up box it should connect to internet.
                      Firstly flash box with KVa750 i-connect firmware 09/09/10.
                      Then fac-reset & scan for channels.
                      Now connect i-connector to box & router. Wait for i-conn. to load update to box. You will see SUCC in display when complete. This firmware is in STICKIES at top of page. Read Satmo's instructions. Now when you select s/w update it
                      should either update or say s/w up to date.
                      Once your internet connection is OK you should look at your
                      signal strength. It should be 70+. You may need to replace
                      faulty cables or splitters. Check sig. strength when box is
                      working & when not working.
                      Last edited by EAMO 2; 2 November, 2010, 22:16. Reason: correcting date on firmware
                      • guppyabby
                        • 232
                        when u said reboot the router do you meen switch on and off.
                        • DW190
                          To reboot you switch off first then switch on.
                          • cactikid
                            • 12017
                            if signal is around 55 do you have bb only which is capped,or do you have a min package and bb.
                            • guppyabby
                              • 232
                              i have min pakage,dont no what you mean by bb
