Gone off in (Knowsley) - Liverpool
  • duglish
    • Feb 2011
    • 87
    I've restarted the router, turned modem off, turned cable box off etc. and nothing comes on at all... is there anything else I can do? Will older version of firmware help or should i re-flash?
  • plasterer
    • 1631
    If your not even getting Free to Air channels
    First thing i would do is ring your SP
    Make sure theres no faults in your area
    As boxes are running at other locations .............Paul
    PAUL
    • duglish
      • Feb 2011
      • 87
      Thanks mate
      There is no faults in the area Would a re-flash work?
      • duglish
        • Feb 2011
        • 87
        ok just reflashed it now and it's just sitting saying 'On' on the front panel
        • plasterer
          • 1631
          You put the correct Firmware on it
          With the 232 cable .
          Will need to be reflashed..............Paul
          PAUL
          • duglish
            • Feb 2011
            • 87
            trying now reloaded the latest firmware, it's searching for the channels now. is there anything inparticular i need to do or just make sure it's set to nagravision?
            • duglish
              • Feb 2011
              • 87
              it's not even working on FTA... what the hell!
              • mtv1
                The Stig PT
                • 4413
                not another starpoo ask maca58 he in pool with kryptview
                • duglish
                  • Feb 2011
                  • 87
                  he around?
                  • Cronus
                    • 692
                    Just checked and mine still working. I'm on the Knowsley TP.
                    • duglish
                      • Feb 2011
                      • 87
                      Kirkby here, Used Knowsley 1 last week and all was fine...
                      Any idea what I could do?
                      • duglish
                        • Feb 2011
                        • 87
                        it's just came on then decided to go back off again, brilliant this, absolutely BRILLIANT :@! Anyone got any ideas?
                        • mtv1
                          The Stig PT
                          • 4413
                          nip round to maca's house his is working http://www.digital-kaos.co.uk/forums.../36412-maca58/
                          • tubs
                            • 420
                            ok if you have a starview it will not work but if you have a kv with lan surport then it should be working so put on firmware then fatory reset makes sure you pick right network ie telwest or ntl etc then make sure you are on network .go to green button and scan find your id click ok .if you dont no your id go to nearest to you and see what happens if you need more help let me no get you up and running in 5 min
                            • tubs
                              • 420
                              most inporting thing is make sure all connection are good this will make a big diffrents to your viewing and reboot router
