How do you connect RS232 to Ethernet?
  • rotexeta
    • Feb 2011
    • 5
    I have just received my kryptview box and purchased the homeplug system as suggested now my problem is tthe box came with no cable and has an RS232 male connection. So I need to get a short cable with RS232 female connection one end and an ehternet male other (an ethernet female would also do). Is this possible or do I now have to purchase a hub as previously posted on other queries. If you know were to get the cable described above please advise. Regards.
    Im a twat the ethernet port is under a black sticker on the back of the box that I didnt see with my crap eyesight
  • plasterer
    • 1631
    [ame=http://www.amazon.co.uk/Belkin-Pro-Serial-Direct-Cable/dp/B0000DG4WT/ref=sr_1_1?ie=UTF8&qid=1297525248&sr=8-1]Belkin Pro Series Serial Direct Cable 3m: Belkin: Amazon.co.uk: Computers & Accessories[/ame]
    If your in liverpool mate theres one here you can have ....Paul
    PAUL
    • pipefitter
      • Feb 2011
      • 21
      maplin sells cables 14 quid
      • rotexeta
        • Feb 2011
        • 5
        Thanks but the cables you are suggesting are just RS232 cables I need to get from RS232 to ethernet (i dont think this is possible in a cable)
        • smoggy
          • Apr 2009
          • 12812
          can't see why you would want to do what you are trying
          the box has an ethernet connection
          remove the sticker near the vcr scart and you will see the ethernet connector for your box
          • plasterer
            • 1631
            Maybe he wants to update Firmware .........Paul
            PAUL
            • freeradicals
              • Feb 2011
              There are lots of cable RS232 to RJ45 network cable adapters out there (google could be your friend here) but you will find most of them at around the ?100 mark. Not seen any cheap ones tbh - maybe try ebay?
              A friend of mine recently needed to remote control some Amp racks via RS232/Serial ports and he found some wifi adapters to RS232 and they were about ?35.
              • cactikid
                • 12017
                if its the 780 kv you need the null modem cable to flash the box the first time,and the lan as said is under the sticker and the scart to tv to view.
                the null modem cable is female at both ends as if you had a pc with xp and serial port it would connect up fine,newer laptops dont have serial/rs232 ports and use the usb port with a usb 2.0 to serial [ male connector ] rs232 adapter cable joined to the null modem cable,all info on hitecks tut for flashing.
                • kojidon
                  • 56
                  I bet he didnt look under the sticker
                  • hillcea
                    • Feb 2011
                    • 10
                    im considering getting a Krypyview 780 since my Starview went down, is the kryptview still getting all the channels?
                    • rotexeta
                      • Feb 2011
                      • 5
                      Thank you Im an idiot with crap eyesight who didnt see the sticker
                      • smoggy
                        • Apr 2009
                        • 12812
                        don't worry your not the first and most probably wont be the last.
                        doesn't matter how you get there as long as in the end you do
