The Box Super USB V1.12
This topic is closed.
starview Firmware Vr 1.12
hi all, I've just joined and tried to d/l the latest firmware for the Starview. Error msg says I must post in the forum before I can d/l so here's my post
Jim.Comment
hey, I'm in an ex TW area (now virgin) everything works fine since the update, except one bug on the EPG, E4 comes up on the bottom and remains, missing a few channels when using the page scroll buttons...
Thanks for the update, works a treat! much appreciated!!!
fairytales who knows what the boxes can or cannot do,25 channels moved to n3 in irl on n*l=no fix yet.Comment
did you factory reset 0000 to delete,coaxial from wall to box auto scan your provider and keycode to onComment
Installed V1.12 then logo file - error "it is not a file of this IRD"
After succesfully installing the new firmware V1.12 on my TheBoxSuperUSB, I then installed the logo file. After it automatically rebooted, the screen turns green and I am asked to choose a language.
If I try to re-install the v1.12 firmware( also tried V1.07 ) I receive an error "it is not a file of the IRD"
I copied the firmware file to the root of USB stick, powered off the Box, inserted the USB stick and then switched on.
Again I am asked to choose language, and then when usb is selected and I try to install the firmware, the same error appears.
Any ideas or suggestions ?
Boot sequence is as follows -
Power on
88 88
88 82
b-01
Green screen
Language select
(logo does not display at any point)
I managed to do a automatic scan and it populated, but when I change channels etc, I can hear the channel but the picture is not displayed.
If I change channel the screen displays a scrambled image.Comment
$ sign problem....
Starview 4 arrived yesterday - installed all necessary software but majority have channels are displaying a $ sign and I can not view these specific channels - any ideas as very new to this....Comment
Hi and welcome to DK
you need to turn the keycode on
Menu/1570/keycode on....exit out and put on to sky sports1 and let it updateComment
