done starview software update still cant find channels
  • pje2011
    • 10
    hi ive reflashed my starview with the new software and not finding any channels S is on 95% and Q is on 10% symbolrate is on auto and QAM is on 64 can any body help thanks in advance pje
  • quavis
    • Aug 2009
    • 117
    channels S is on 95% and Q is on 10%............................................... .................................................. ............... low quality that!
    • Mackum
      • 82
      Try a different symbol rate. and make sure u dont have any splitters on your incoming VM connection
      • lenordy
        • Mar 2009
        • 244
        put the symbol rate in manualy try 6952 then delete all channels and rescan.
        • pje2011
          • 10
          hi when i do that the the scan freezes give me S 95% Q 95% but soon as it unfreezes and keeps scanning it goes back to S95% and Q 10% thanks for the replys
          • lenordy
            • Mar 2009
            • 244
            if you say where you are in the uk someone can give you the correct symbol rate for your area.
            • pje2011
              • 10
              im in oxford thanks
              • safc1234
                should be 95s 95Q,
                • lenordy
                  • Mar 2009
                  • 244
                  im in oxford thanks
                  the symbol rate i posted was for the manchester area any one no the symbol rate for oxford please post.
                  • Mackum
                    • 82
                    Theres only 3 just try them all goto channel 511 type 1819 on the remote to see if there activated.
                    • cactikid
                      • 12017
                      Oxford 1 N*l, 00020 578250 6887
                      Oxford 2 N*l, 00020 818250 6887
                      Oxford 3 N*l, 00013 803000 6887
                      make sure you scan from direct feed and lan removed and insert when channels loaded,and box and router and modem may need rebooting
                      • alcros
                        • 32
                        how do i change the symbol rate
                        • davegards
                          • 24
                          Go on auto search then on symbol rate and move it left or right ro your symbol rate then press search
                          • alcros
                            • 32
                            starview 7
                            loaded new bin file got sky sports1+3 says connected on most channels but no picture
                            • alcros
                              • 32
                              do you know the symbol rate for manchester
