done starview software update still cant find channels
  • davegards
    • 24
    #16
    Only a few channels working at moment pal have a look on working channels it will tell you what's on being added gradually
    • isotonic_uk
      • 70
      #17
      Originally posted by alcros
      loaded new bin file got sky sports1+3 says connected on most channels but no picture
      I got the same issue as this... Got SP 1 and 3....
      • pje2011
        • 10
        #18
        hi tried every thing direct feed sybol rate 6887 cant find any channels im using the showmustgoon is the the right file? thanks
        • davegards
          • 24
          #19
          Try the two other symbol rates should find about 300 channels just under or just over but only a few channels working at moment
          • king23
            #20
            Have you rebooted after flash, and then Resanded, after that go on to any channel and just type 1819 on remote, it should say enabled
            And your not having issues if you have sky sports 1 and 3, that's basically all there is, read the numerous thread stating this
            • lenordy
              • Mar 2009
              • 244
              #21
              do you know the symbol rate for manchester
              6952 for manchester area
              • pje2011
                • 10
                #22
                went back to carling-104 and i can find channels but cant find channels with the showmustgoon can anyone confirm this is the right firmware thanks pje
                • pje2011
                  • 10
                  #23
                  its ok ive sorted it installed carling-104 scaned channels then installed showmustgoon never done factory reset went to ssp1 and put 1819 and it worked thanks again everyone for trying to help pje
