ok ?10 paypal payment to who gets me up and running
This topic is closed.
  • hollandish1
    • Dec 2010
    • 54
    #31
    no jumper on this box.
    cactikid i have already done all that, i have the 12/5 file on there but have got no where with it.
    • celticnthell
      • 52
      #32
      If there is no jumper then reflash the box and scan using the proved cable that's in the modem
      • hollandish1
        • Dec 2010
        • 54
        #33
        tried modem cable already, also tried the one going into the virgin box. and also tried the main one coming into the house. all with same results. i think its got to be a problem with the box.
        • jim 75
          • Feb 2011
          • 79
          #34
          have you tryed taking new software off and puting it back on factory reset scan for channals with conecting to net when u finished put the internet cable in press 1819 on ssp1 switch it off for a while about hour c wot happens then if not working then dont no m8
          • jimbo 7
            • 13
            #35
            sure you extracted ups from rar file then put on usb stick which is formatted to fat 32.just a guess ,let us know how uget on.
            • hollandish1
              • Dec 2010
              • 54
              #36
              did all that mate
              • hollandish1
                • Dec 2010
                • 54
                #37
                still only 4 channels its picking up
                1 channel 4hd
                2 discovery hd
                3 nat geo hd
                4 eurosport hd
                none of which give any picture, prob cuz its not an hd box.
                my head is melted!
                • lac
                  • Apr 2011
                  • 213
                  #38
                  On your VM box Setting/Tech Stuff does the Net ID show
                  00015 is so scan of NTL.
                  When your fathers box was used he may have had a different provider
                  Clutching at straws not teners.
                  • hollandish1
                    • Dec 2010
                    • 54
                    #39
                    hes on the same as me
                    • smoggy
                      • Apr 2009
                      • 12809
                      #40
                      just a bit of info
                      Walsall (the nearest I can see to Tamworth) was ex TW which is symbolrate 6952
                      that was before nag3 but I suspect its still the same
                      • Shady
                        Shite Link King
                        • Dec 2010
                        • 6404
                        #41
                        tamworth is ex ntl..so 6887
                        • cactikid
                          • 12017
                          #42
                          my point was faulty firmware can cause problems,thats why i wanted you to erase it on stick and download a fresh one and reflash it again as that will default settings incase you changed something
                          • smoggy
                            • Apr 2009
                            • 12809
                            #43
                            I don't know what options a SV 7 has but on the older starviews you could do a manual scan
                            if you get a channel frequency off your subbed box you could try manually scanning that frequency to see if you can pick anything up
                            • lac
                              • Apr 2011
                              • 213
                              #44
                              Smoggy,I presume you mean his Net ID which is 00015.
                              He is only picking up two different TPs which I believe is the lowest TPs on the box.155.000.& 163.000
                              Manual scan staring at 195.000 may work.
                              • hollandish1
                                • Dec 2010
                                • 54
                                #45
                                thanks guys, does any1 have a link to a guranteed working firmware?
