Starview 2 Set-up
  • Callisto99
    • 7
    Starview 2 Set-up
    New to the forum and I'd appreciate a bit of help. I had Starview 2 working until yesterday. I attempted to re flash and now am in a situation now where I can only get the main menu.
    When i plug the lead into the box the laptop prompts me to install hardware for the box, I just cancelled this????
    Anytime I try to re flash it tells me flash failed when tried to run the new firmware or any firmware.
    Any advice people?
  • mod2000
    • 82
    [QUOTE=Callisto99;106498]Hi,
    Any advice people?
    what do you mean only main menu if it comes on it should be working
    • Callisto99
      • 7
      The Box
      Hi mod,
      Thanks for the reply
      The box was working - ie I had a number of channels. Now when I turn it on I just get the main menu - with parental control and channel edit greyed out - and cannot even exit to the channels I had already. Any idea what the trouble could be pls?
      • mod2000
        • 82
        Never seen this mate can you get another sv2 and flash from it
        • mod2000
          • 82
          Originally posted by Callisto99
          Hi mod,
          Or can you do factory reset
          • Callisto99
            • 7
            Factory reset
            I presume a factory reset is just clicking on factory settings?
            If so ive done this.
            Also, when I try to flash it just stays at 0% and eventually comes up with flash failed......
            • mod2000
              • 82
              It sounds like you put wrong flash try switch box off load loader hit download then switch box on.
              • Callisto99
                • 7
                Flash
                I've tried downloading with the box on and on standby (with just the time showing) and no good - still get the same flash update fail....
                • mod2000
                  • 82
                  what lead are you useing
                  • Callisto99
                    • 7
                    Lead
                    Its a serial to USB lead lead I am using....
                    • mod2000
                      • 82
                      Have you installed the drivers
                      • cng1958
                        • 21
                        Try different comm ports or different usb slots,sometimes you have to keep on trying until you succeed
