Hi there i wonder if any one can help me out here i have flashed my Starview box, then scanned for available channels,brought up the hidden menu and pressed the EMU to on. Up to this point every thing is ok but when i go to my channels it just keeps updating continuously. Any idea any one
Starview 1 help required
If you've flashed your starview 1 with the latest firmware and the box has sucessfully scanned in your channels , it's a genuine starview , as the fix wouldn't work on a clone Mate.
Check you've flashed it with the correct firmware , as it sounds
like it wants the keys putting in manually were it should autoroll .Comment
It was never a great box for EPG. But make sure your time settings are correct, turn the box off from the back switch and then back on.
It may improve it slightly.I refuse to answer that question on the grounds that I don't know the answer. - Douglas AdamsComment
Latest firmware versions for the SV1 is here Digital Kaos - Downloads - Starview 1 UK AU Fix v1.5
You will see two files, one for a clone and one for a genuine. It will indicate which is which in the download notes.I refuse to answer that question on the grounds that I don't know the answer. - Douglas AdamsComment
