Starview 1 help required
  • thedon6915
    • 18
    Hi there i wonder if any one can help me out here i have flashed my Starview box, then scanned for available channels,brought up the hidden menu and pressed the EMU to on. Up to this point every thing is ok but when i go to my channels it just keeps updating continuously. Any idea any one
  • martin-f
    • 535
    menu 1570 set default key make sure emu is on and try again
    • wilf
      • 1618
      This can take quite alot of time to update sometimes aswell, up to 2 hours rather than minuites. Do you know for sure if it a clone or not, its best to flash with core-257 if not sure as this will fix both clone and genuine
      • melloned
        • 1215
        If you've flashed your starview 1 with the latest firmware and the box has sucessfully scanned in your channels , it's a genuine starview , as the fix wouldn't work on a clone Mate.
        Check you've flashed it with the correct firmware , as it sounds
        like it wants the keys putting in manually were it should autoroll .
        • thedon6915
          • 18
          thanks for the support guys
          • j-lee
            • 5
            Just to add to the confusion. I have flashed a starview clone with the 400 flash and its fine.
            Not getting all the EPG data though could this be somthing to do with the 400 flash???
            • satsmo
              • 6397
              It was never a great box for EPG. But make sure your time settings are correct, turn the box off from the back switch and then back on.
              It may improve it slightly.
              • j-lee
                • 5
                Thanks for that I'll give it a try and let you know.
                Might try the 257 flash see if its any different..
                • satsmo
                  • 6397
                  Latest firmware versions for the SV1 is here Digital Kaos - Downloads - Starview 1 UK AU Fix v1.5
                  You will see two files, one for a clone and one for a genuine. It will indicate which is which in the download notes.
