SV2 no channels found..?
  • ozshea
    • 234
    got a box to flash from a friend it just says the box on the top left hand corner so i take it its a starview 2, got the loader and new fix from the downloads section, flashed the box it came up flashed sucessfully, i done an automatic scan for my area came up as no channels found, when i go to any channel it says scrambled or bad channel then it changes to no signal, i set the default key and turn on key emu and it still does the same.
    any suggestions...??
    thanks oz
  • camelv
    • 1202
    do a factory default m8 then set default key and emu to on then rescan it.once the scan has finished leave on sly sports 1 to update.
    its the stuff we think we know that stops us all from learning
    • ozshea
      • 234
      i go to factory setting put in 0000 and the box where i enter the 4 zeros is just poppin back up again, im thinking thats its the wrong password, is there a default password that i can enter,
      thanks for your help.
      • camelv
        • 1202
        try 1004 m8
        • ozshea
          • 234
          i got the password from the chap who owns the box, done a factory reset turned on key emu, done another scan, it came back no channels found...
          its a puzzling one......
            re scan first m8 then turn key emu on
            • ozshea
              • 234
              yeah tried that still coming back no channells found,
              any other sugestions...????
                might sound silly have you got right provider
                • ozshea
                  • 234
                  yeah the right provider, have done plenty of SV1's,
                  will i reflash it and see what happens....???
                  • ozshea
                    • 234
                    yeah tried all that, still the same and the box only has 1 coax input unlike the SV1 so its in the right place, just reflashed it and still the same....
                    • jackd
                      • 67
                      my starview the box super was doing the same just kept on reseting it and doing scan its just started to work now
                      but i was doing it 4 2 days
                      • ozshea
                        • 234
                        it just says the box in the corner im on ntl cable, dont no if the owner is on mmds, but i flashed it with SV2 fix for cable and scanned my area so id imagine it should work for me in my area now.
                        • ozshea
                          • 234
                          ok was talking to another chap who does boxs in my area, if the box was mmds there would be an option to turn on a power supply through the coax out socket to power the arial and this function is not on this box so i can definitely say its a cable box.
                          • cactikid
                            • 12017
                            n*l mmds and cable use same box as in dvb/c only c****s mmds use t boxes as in dvb/t.
                            what vers is in system info for starters???
                            is coaxial going into cable input,and are u scanning N*l in provider.?
