Starview 7 Firmware 3.00 Problems
  • cbk
    • 39
    #16
    Originally posted by Moore606
    All sorted. Cheers!
    what did you do to fix it?
    • 2broke
      • Jul 2012
      #17
      Mine is still freezing whenever i select the software, and no one is willing to help :'(
      • 2broke
        • Jul 2012
        #18
        Originally posted by 2broke
        Hi all could someone help me please, i've tried to load the new firmware but it just won't upgrade. Ok here is what i've been doing.
        I go menu>utility>usb>Veiw 3.00.ups>frozen .Happens every single time,it just freezes as soon as I chose view 3.00.ups, have to turn off the power at the back to start again. I have got a SV7 exp. date in Sept. please help
        Just an update, everything is all sorted now..very happy bunny,special thanks to 'nicole123', he is my hero
        • michelleuk
          • May 2010
          #19
          mine like that to ;( have you fix yours yet
          • nicole123
            • May 2010
            • 326
            #20
            sounds like your usb stick is not formated to fat32?
            • joshim
              • Jul 2012
              • 8
              #21
              hi all, please can someone help. i have downloaded the firmware 3.0 on a usb stick. I clicked download and saved on usb. is that right.
              Now I have a usb stick with a file on it not sure if its in right format. What do I do now? I push it in back of box
              and then what do I do? i went to menu, utility then usb clicked on it. it shows a file called fat32. from here i get stuck. Please HELP me
              • cactikid
                • 12017
                #22
                it should have a file called view 3.00ups i think,reformat pc stick so there is nothing on it,copy the above file to usb from pc and go from there,always insert usb into box when powered off [and removing also ]
                when downloading onto pc it may be a compressed file like rar which needs extracting first.
                • joshim
                  • Jul 2012
                  • 8
                  #23
                  Thanks cackikid mine is sorted now
                  • iffykaz
                    • Jul 2012
                    Hi i downloaded file 3.00 from tech kings for starview 6 and 7 and it worked fine all channels back and running
                    • cactikid
                      • 12017
                      #25
                      its also here if people looked at the starview section.
                      • nbyrne
                        • Aug 2012
                        just installed 3.0 works fine thanx to all
