Starview 4
  • welshwilly
    • 30
    Starview 4
    Hi Gents.
    Great site, Been on here a short while whilst deciding what box to get so I bought a Starview4 Super Box usb. downloaded the latest 1.07 upgrade etc into the box & followed the instructions to the tee,
    I can get the normal NTL channels etc but nowt else..
    Where have I gone wrong ???
    I have been reading this site for a few hours trying to get my head around it, I can normally manage things like this but the box nearly went out the window with the wife
    Any help greatly appreciated
    Will..
  • camelv
    • 1202
    Originally posted by welshwilly
    Hi Gents.
    Great site, Been on here a short whilst deciding what box to get so I bought a Starview4 Super Box usb. downloaded the latest 1.07 upgrade etc into the box & followed the instructions to the tee,
    Will..
    Do a fec reset on box m8 then set default then set keycode to on then autoscan ,should be ok then if you are in the uk.
    its the stuff we think we know that stops us all from learning
    • welshwilly
      • 30
      Cheers Camelv
      Im in south wales 2 miles away from NTL HQ
      I will give what you say a try.. I'm getting grayer by the minute..
      Will..
      • pukata
        • Apr 2009
        iam in south dublin and have digivox and the box super4 and on ntl as iam writing this , all the channels are gone so how do i get code to put the channel back
        • mtv1
          The Stig PT
          • 4413
          new keys on bigmaq toolbar cheers
          • mtv1
            The Stig PT
            • 4413
            sorry guys only chor*s keys updated on bigmaq not n*l keep an eye on it though sorry
            • welshwilly
              • 30
              Camelv just did what you suggested above and no succsess
              whats my next move apart from hitting it with a 2lb hammer
              Will..
              • Lanxman
                • 552
                Will..
                Try scanning on a different provider like telewest instead of ntl, We're in an ntl area but scanning on ntl didn't work for whatever reason but when we scanned on tw it worked. Worth a try m8.
                Sometimes a slow gradual approach does more good than a large gesture.
                • Archmage
                  • Apr 2009
                  • 18
                  quote
                  I just set up on of these with no probs, what else were you expecting?
                  do you mean you are only getting fta channels?
                  • welshwilly
                    • 30
                    Hi Lanxman
                    I tried that one, I scanned TW and I didnt get a channel up.
                    so I re-scanned NTL & I have all the channels showing but the majority showing the $
                    Will..
                    • welshwilly
                      • 30
                      Originally posted by JoK
                      Have you definately got v1.07 f/w properly installed?
                      Press menu, system setup, system info and check s/w version, should say 1.07.
                      Can you access the cas menu?
                      JoK
                      Hi Jok
                      Yes I downloaded it earlier from the above DL Link (look at my download record and I think they were all done today)
                      Checked the system set up and it does say 1.07
                      Will..
                      • Lanxman
                        • 552
                        Hi Lanxman
                        Will..
                        You should be able to view the $ channels. Have you set your keycode to on as camelv said? Go to menu and key in 1570 this will bring up the secret menu where you can set the keycode to on.
                        You tried that mate? If you have done all this then try turning the box off and then flicking the main power switch off at the back for a few seconds and then back on again and see if you can view them then.
                        • welshwilly
                          • 30
                          Originally posted by Archmage
                          quote
                          Hi Arch
                          Yes mate only FTA channels available
                          Will.
                          • welshwilly
                            • 30
                            Hi Lanxman
                            Yes done all the above, the only thing I havent done is switch off on the back of the box, I will give it a try..
                            I'm having a mare with this one.. been at it since 10.30 this morning
                            Will..
                            • davi367
                              • Mar 2009
                              • 10
                              Hi Arch
                              Will.
                              Turn on the EMU
                              menu~1570~key emu (turn on)
