Can someone tell me what is the biggest drive can I connect to these units ?
Starview hd combo
I am currently using a 1Terrabyte portable hard drive no problems. Can get cheap on fleebay look for a western digital my passport. Tried them all up to this size and they work no problems. You will also need to download from the net a tool to format the drive to fat 32 as the drive will not work straight out of the box on your starview combo. Loads of free format tools on the net.
Also forget using a usb stick over 10g as you will run into stuttering issues when recording anything in HD.Once upon a time it was all about backdoor 0 passwords, now its only about the rsa keys !!!!!!!
If this post has helped you........... Don't be shy and hit the Thanks button..
yes try the i was bored one day files from the download section , you can flash your box with spder firmware or mvision , both work goodComment
