Just set up Starview 4, Can't Get A Thing - HELP
  • c0ld4orm
    • Apr 2009
    • 5
    Guyz,
    I purchased a starview 4 box recently. Last night i tried to get it going;
    I uploaded firmware v1.09 and the logo file.
    I turned on Keycode.
    I took scart and cable leads from ch***s box and put into the back of the starview 4 box.
    I then tried scanning on all providers, but I couldnt get a thing! Is there anything I'm doing wrong?
    Can i try to scan manually?
    I'm based in Ireland, so is it even pointless at this stage?
    Can anyone help?
    Thanks in advance for any help anyone gives.
    c0ld4orm
    http://www.myspace.com/heavensfallofficial
  • bigfella
    • 879
    Originally posted by c0ld4orm
    Guyz,
    Can anyone help?
    c0ld4orm
    well have heard boxes r goin down in ireland changed from nag 3 to nag 4 i thinks so u may be unlucky altho i would have thought u would still have got the free view channels ..so might be a problem with the flash ....go to menu ..goto system set up goto system set up and it shud tell u wat firmware u have flashed to ur box
    • c0ld4orm
      • Apr 2009
      • 5
      Originally it had firmware v1.07 but I loaded firmware v1.09.
      Will I switch it back to v1.07? do you think that will do any good?
      Thanks for the reply
      • bigfella
        • 879
        make sure all ur leads r in
        • gazza2008
          no coz V1.07 is uk m8
          V1.09 is ireland
          • c0ld4orm
            • Apr 2009
            • 5
            I took the cable lead and put it into back of SV4, and also the scart lead.
            I have keycode "on"...anything else you guys can think of?
            • cactikid
              • 12017
              bigfella u are jumping the gun ,boxes are going from 1-2 and maybe 3 dont know where 4 has come from,and usb in ireland no fix.
              • c0ld4orm
                • Apr 2009
                • 5
                Cheers, Thanks for the info!
                • bigfella
                  • 879
                  well i did say,,, i thinks,,,,the important bit was the nag encription was changing ..any other nick pickin ????
