need help please
  • Time2Play
    • Apr 2009
    • 309
    need help please
    hi i have astarview 4 box which i bought off a friend he said there is away to repair but he is not sur ehow i have posted many ptopics i came across 8882 error so i thougth ok then i bought a max 232 INTERFACE OFF EBAY iv plugged it up and it wont seem to download but my box is not showing 8882 error its more random stuff such as 8888 or ffff or 0000 or some times jkust half of each number any ideas on what i can do please thanks
    SAY THANKS OR JOK WILL TAKE PICTURES OF YOU IN YOUR SLEEP
  • chancer
    • Aug 2008
    IF YOU HAVE A STARVIEW 4 THEN YOU SHOULD BE PUTTING THE FIRMWARE ON BY USB WHICH YOU GOT WIYH YOUR BOX
      hey m8 i see u used your e-mail as a user name not a very good idea m8, if u want it changing pm admin which is devilfish.
      • smoggy
        • Apr 2009
        • 12810
        only one problem now is, he has changed his addy to remove EMail address but it is still there in your quote box
        EDIT : I see you have now edited post and removed it
        • Time2Play
          • Apr 2009
          • 309
          Originally posted by JoK
          Have a read of post 38 on this thread http://www.digital-kaos.co.uk/forums...23/index3.html
          Have you followed this?
          JoK
          hey i followed everything but the null cable is the null sable a nessesity
          • Time2Play
            • Apr 2009
            • 309
            Yes m8 it is, NULL cables are wired differently to a serial cable. They only cost a few quid, try here Play.com (UK) : DB9 Female DB9F 9 Pin RS232 Serial Null Modem 2m Cable : Computing - Free Delivery.
            Once you have the sv4 up and running again you will just flash the box using the USB port.
            JoK
            hi i have one of those serial cables you linkled me to it came with the starview box i origanlly had but the ends of it are the same as the ends of the jtag i got
