Starview 4
  • lolanre
    Starview 4
    Hi guys
    Can someone help pls just got starview 4 box downloaded the super box firmware connected it onto my digital tv scanned the channels automatically. I only get the local channels all the the freeview channels has disappeared. I'm i doing something wrong can someone help pls.
  • boomer39
    • 2818
    Originally posted by lolanre
    Hi guys
    have you done menu, 1570, keycode on?then press default,then back to 511..ynwa
    YNWA..
    • tinkerman
      • 4
      Hi, I am having the same problem. I have tried to factory set .... install but could go any further. When I go to menu I get the usual ... intallation to Usb. I enter 1570 but nothing happens.-- Where is the secret menu??? Can some one help please.
      • smoggy
        • Apr 2009
        • 12811
        if you only have the free to air software on the box the secret menu is not available, have you loaded the latest firmware
        • Grayers
          • 5
          latest Firmware
          Does anybody know what the latest is 1.08?
          mine fell over the other day and can't get it back up
          cheers
          • Grayers
            • 5
            Many thanks followed your comments and it worked how does it turn off ???
            • Grayers
              • 5
              starview 4 in Spain
              Hi All,
              has anybody taken one of these boxes to Spain, its on a po1aris Wor1d site near Murcia,
              did it work,
              Can it work
              the robbers want 400 euros for their box
              any help would be ace
              Manythanks
              • boomer39
                • 2818
                dont think so.btw,what do you mean by how does it turn off?
                latest f/are is 1.07, has been for months. when things go awol, try menu,1570, hit default(make sure keycode is on), then back to slyspts... ynwa
                YNWA..
                • dongledangle
                  • 4
                  Originally posted by Grayers
                  Hi All,
                  did it work,
                  Can it work
                  Manythanks
                  Grayers,
                  I'm out there on June 2nd, back on June 9th ! Will let you know how I got on. I bought one recently and am about to take it over.
                  Having played about with the box at home (I'm not in a cable area) I don't think the auto-scan will help as it's looking at the specific frequency ranges and other settings used in UK and Eire. I need to collar a resident, play with their box, note all the frequencies of the English channels then input them all manually in my box. If the channels are FTA then it should work. If they are scrambled then we are stuffed. The firmware update mentioned on this forum seems only to apply to UK and Eire. Unless someone tells us otherwise, I don't think it will help.
                  • kirsty
                    i have just purchased a starview 4 superbox and have not received the instruction manual could anybody send me one please.
                    • bigfella
                      • 879
                      kristy if u want the instruction manual ..get on to ur supplier they shud send u out ..if u want instructions how to flash ur box with the lastest firmware so u can view the dollar channels ie all the channels available......well u can get a tutorial in the downloads section on this site in the starview part ...u ll need winrar to un zip the tutorial ( if u havent got winrar) u can also find in the downloads part under the p c part ..........if u read thro the threads all the answers r there ...if u get stuck ,,ask theres plenty of good peeps to help
                      • majid
                        • 5
                        Hi i have had the starview 4 for a while now and suddenly my sky 1 has stopped working? any ideas on what could have went wrong.
                        • mtv1
                          The Stig PT
                          • 4413
                          depends did yo rescan some times they change transponders
                          • bigfella
                            • 879
                            try a factory reset and remeember to turn the keycode n default back on
                            • kirsty
                              hiya having the same problem. my s/w version is as follow
                              Originally posted by JoK
                              Press Menu button
                              Goto System Setup
                              Sytem Information
                              And look at s/w version
                              Post back what it says here.
                              JoK
                              having the same problem my s/w version is as follows:
                              model id- c500
                              s/w version- 1.06
                              boot version- b-11
                              date- dec 10 2008.
                              i am a first time buyer of one of these boxes and have no clue what to do next please help.
