Starview 3 Box Super
  • billyboy73
    • 37
    i had the 8.02 on the box now i've put the the 8.04 on it and it wont scan it will go up2 100% with no channels found i put the 8.02 back on it and it does the same i took it round my mates house (who has a working box) and it done the same .I'm stuck can any1 Please Help
  • smoggy
    • Apr 2009
    • 12809
    have you got the cable feed into the correct socket
    are you scanning on the correct cable provider
    is your mates a starview box, if so you could put his channel file on yours
    • billyboy73
      • 37
      my mates is the same it was working before i changed to 8.04 i also tryed to put keys in manually but just wouldn't pick anything up how would i transfer the channel file .Thanks
      • smoggy
        • Apr 2009
        • 12809
        you should be able to pick channels up if you are scanning on correct provider.
        To get channel file you would have to upload his channel file to a PC and then download it to your box
        EDIT : is your mate in the same area as you as the channel files are specific to the area your in
