Starview 3
  • hkhalif1
    • 21
    Starview 3
    Starview 3 has gone off is there a new firmware for this box or is it manual key updates?
  • smoggy
    • Apr 2009
    • 12810
    the codes have rolled the last three days running, but if you have the latest firmware on your box it should still auto update them if you have previously been inputting the codes manually then you will need the new ones as they rolled again this morning
    • khenryashley
      • 783
      Check what firmware you have on the box.
      Menu
      system info
      Should be 8.02 or 8.04
      If not you need to update firmware or key manualy
      • johnwelsh
        • Sep 2009
        • 27
        also the new codes arent working yet,any ideas?
          if the new codes came out this morning they will be working now. have you done a rescan. right provider. also what firmware is on your box why not just update it.
          • nicebelly2003
            guys i have a starview box super. i tried to install the 8.04 on teh box, the only option i was allowed to use when downloading was using: serial port COM3: baud rate 115200
            but when i select download, i get an error saying flasc failed. this is the same whether or not the box is on or off.
            any help appreciated
            • khenryashley
              • 783
              When flashing the box press download then switch the box on.
              R u sure you cant opt for another com port in the drop menu
              • jackson07
                • 5
                i am on 8.02 version and mine is updating ok, only trouble i 've some channels with bad/scrambled on, any ideas on geting them working?
                  [QUOTE=jackson07;303430]i am on 8.02 version and mine is updating ok, only trouble i 've some channels with bad/scrambled on, any ideas on geting them working?[/QUO
                  try this version m8 http://www.digital-kaos.co.uk/forums...3-8-04e-14963/..
                  • boomer39
                    • 2818
                    normally all you need to do is menu, 1570, default. then exit to sly spts1, leave to update.
                    YNWA..
                    • jackson07
                      • 5
                      thanks for those, my sly channels are ok though, but i get a no signal for channels 1-5 and loads of kids tv channels are scrambled as well as the new e**n sports.
                      i've no idea about firmware etc, i've never done the downloads myself, what cables etc would i need to put the 8.04 onto my box.
                      • khenryashley
                        • 783
                        You should not have a problem with 8.02. 8.04 was a little ugrade(nothing major)
                        Try doing a factory reset and rescan.
                        You will find instructions how to do this in previous threads
                        • jackson07
                          • 5
                          many thanks khenryashley!!
                          • nicebelly2003
                            thanks for reply, have tried again but failed
                            not sure ive explained correctly.
                            1st
                            im based in dublin ireland, so not 100% sure if this will work here.
                            2nd
                            not sure how to flash the box,
                            im doing the following
                            running GTRom super 8.04, i can only select COM3(all other options for the serial port tell me they cannot open the serial port)
                            when i run COM3: serial port, baud rate: 115200, STB setting/BIN file: left greyey out(blank), File type: app file only
                            with these setting selected i select download, and a couple of seconds later i get a message saying downloading 0%, then pop up box "flash update failed"
                            • tamgunner
                              • 691
                              no chance of it working at all they have the new encryption over there
