Data Is Being Updated - Starview4
  • whatmaz
    • Mar 2009
    • 21
    Whenever the starview is turned off for a long period of time then swithced back on the message ''date is being updated'' appears, first it appeared on the skysports channels now it seems to have moved to the box office channels, it appears for a minute or so then everything is back to normal again, it would be brilliant if anyone had any info on this
    Maz
  • akbarirfan
    • Sep 2009
    • 93
    Dude I think that means that the keys have changed since you last switched on and now they are being updated to unlock the channels you mention.
    I am no expert but that is my understanding!
    • larryoke
      • 404
      Maz
      This will happen everytime the keys are rolled, basically it means your box is working fine, it will only happen once on a pay channel and then all will be ok
      • gerald5445
        • Sep 2009
        • 143
        me having probs too some chs such as sxy movs.spoxxt xxx some are black screen some are sound only
        • bigfella
          • 879
          check ur leads m8 esp your scart leads r in tight
          • b j m
            • 21
            the same happend to me on saturday i did a factory reset then scan for new channels then pressed menu 1570 and all worked fine
            • gerald5445
              • Sep 2009
              • 143
              now on 0110 living hd v media is showing info about a new smart card is this nag 3?
              • mufc
                hi guys, just put my box on (the box suer usb), on sky sports and hav got system being updated, it then went to a black screen with nowt on, can any1 help please, many thanks.....
                • larryoke
                  • 404
                  if you have other $ channels try deleteing ssp1 then rescan it should come back, if not factory reset then auto scan,
                    rescan your box and remember to turn key code on....
                    • ukmale_121
                      • 8
                      hi guys where is the key section gone....
