Starview1 Box Help
  • THEREALBIGG187
    • 12
    Starview1 Box Help
    Hi there people excellent forum love it , anyways just a quick question bit of noob but we all gotta start somewhere my friend has a star view box think its version 1 cause just says starview on front and is small silver one anyways he is hardly getting any channels its in the dundee scotland area, i have tried entering keys manually but not sure if right ones i have the magic toolbar with all keys and files or will i need an update sorry if this has been covered but cant seem to find exact answer looking for.
    The code is saying ntl but its a virgin feed do i change this if so how? thanks in advance
    Box Details:
    API: Ver: 257eE
    Boot Ver: 7.0
    16 August 2006
  • smoggy
    • Apr 2009
    • 12771
    Hi and welacome to DK
    the latest firmware for the SV1 is the crypstar v1.5 core 400 for genuine boxes core 257 for clones, if you are unsure use the core 257 clonesafe version as this is ok for both.
    Digital Kaos - Downloads - Starview 1 UK AU Fix v1.5
    you are ex Telewest so you need to scan on TW and keys for 5A01
    Last edited by smoggy; 4 November, 2009, 18:27. Reason: provider changed from 5C01 to 5A01
    • THEREALBIGG187
      • 12
      Hi there is it easy enough to add these bin files ill need to purchase a cable first, then what software do i use to upload to the box? just the name is fine as got access to all these files ill let you know how i get one iv tried changing to telewest but its still saying ntl in the nagra secret menu any ideas? thanks in advance.
      • THEREALBIGG187
        • 12
        Got the loader GtRom v4
        • mtv1
          The Stig PT
          • 4413
          change provider by pressing the over button or volume up button
          • THEREALBIGG187
            • 12
            Will this cable do the trick? USB to RS232 Serial 9Pin DB9 Cable Adapter PC PDA GPS on eBay (end time 25-Nov-09 15:35:09 GMT) once i have flashed it will the box be ready to go again?
            • smoggy
              • Apr 2009
              • 12771
              last post of mine should have said 5A01 not 5C01
              if you change the number to 5A01 in the provider ID it will change to Telewest
              • THEREALBIGG187
                • 12
                Which menu to change provider in the secret 1570 one of in the installation one smoggy?
                • smoggy
                  • Apr 2009
                  • 12771
                  if you want to scan in the installation menu (edit as MTV indicated)
                  if you want to input k*ys in the nagravison screen
                  • THEREALBIGG187
                    • 12
                    Thanks ill order a cable and get it flashed let you know how i get on
                    • smoggy
                      • Apr 2009
                      • 12771
                      you need a rs232 NULL modem cable to connect box to PC, if your PC does not have a rs232 port you will also need a usb to rs232 adaptor
                      once box is flashed with latest firmware it will automatically update codes
                      • THEREALBIGG187
                        • 12
                        Not got that connect will this one do? USB TO MALE RS232 DB9 SERIAL NULL MODEM CABLE ADAPTOR on eBay (end time 04-Nov-09 18:29:12 GMT)
                        will i need another one or just that one thanks for this help smoggy ur a star
                        • smoggy
                          • Apr 2009
                          • 12771
                          it would work but you would need a gender bender (female to female) as that has a male end and the box has a male end, easier to get the two seperate cables
