Starview HD Combo LAN & NON LAN STBs
  • satsmo
    • 6397
    Non LAN, (No ethernet port), Combo Serial latest firmware http://www.digital-kaos.co.uk/forums...al-model-1116/
    The NON LAN, serial only boxes were the first 500 batch that were released.
    CAPABLE OF RECEIVING SATELLITE AND CABLE TRANSMISSIONS SIMULTANEOUSLY
    INDEPENDENT SATELLITE AND CABLE HD TUNERS
    EMBEDDED TWIN CI SLOT
    EMBEDDED CARD READER
    2 X USB PORTS
    PVR READY VIA BOTH USB PORTS
    Supports MPEG-2, MPEG-4 H.264 and fully DVB Compliant
    Diseqc 1.0,1.1,1.2 and USALS
    Aspect ratio adjustment 4:3 (16/9 crop) 4:3 (16/9 letterbox) 16:9 (4/3 pillar box)
    User friendly OSD and Operation
    Total 8000 Programmable Channels
    Multi Language audio support & Multi-Language Menu Text Support
    Favorite Channel Selection
    parental guide and rating control
    EPG (provider Electronic Program Guide) Inc on screen channel info
    On-screen Display with 65,356 color
    Blind Scan (powerscan) and powerful EPG
    8psk Turbo FEC Option
    Zoom function in pause
    Dolby Digital Bitstream out through S/pdif (Optical and coaxal)
    selectable output for 1080i,720p,480p and 480i format
    Multiple video outputs HDMI 1.1, Component (YPbPr) Composite
    USB 2 Host (access to HDD, USB memory, Others ect 2 x ports onboard
    Upgrade software and channel list via usb2.0 and rs 232
    MP3 file play by usb2.0
    Recorded file play on PC
    Reservation recording via EPG
    I have not tried this box out yet, but would be interested to see how others will fair out with it.
    I will sticky it for now.
    To Flash Box:
    Load grooverider file on to your usb memory stick, make sure power is off on machine.
    Insert the memory stick into the front usb socket underneath the front flap.
    Turn the HD Combo on.
    From the main menu go to Utility and then press the right arrow button and select usb from the right hand side, you will see the grooverider file press ok on it and make sure to select SW+ALL DATA UPDATE.. the machine will update and restart (don't pull your memory stick out until the machine has fully started up).
    MAKE SURE YOU LOAD THE GROOVERIDER FILE FIRST THEN THE BOOT FILE FOLLOWING THE INFORMATION BELOW
    How to Upgrade inc new boot file.
    1) File name GrooveRider_HD_Combo_F3.50_1118.uad upgrade with S/W + All Data Upgrade first.
    2) Then Upgrade again withBoot_V0021 ( type : sw upgrade )
    3) Power on/off at the back and then factory re-set
    Check your system information says LDR:Ver 00.21
    You now need to scan your channels, so go to installation press the right arrow button again and go down to AUTO CABLE SEARCH all you need to change here is the symbol rate.
    The symbol rate determines your area for example nt* is 6887, the other 6952 are for telewe*t and EXc&w.
    When you have selected your area go to start scan.
    Once the scan has finished go to menu then highlight accessory and on the remote press the numbers "8989" you will then see
    "keyedit" appear on the right hand side, go to it and press ok and just check that auto update is on if its off just turn it on.
    then go to to your channels by exiting the menu and pressing ok.. Select a non FTA channel and leave it until a picture appears
    PLEASE NOTE IT CAN TAKE UP TO 5 MINUTES TO UPDATE
    Channel list..
    All your channels are categorised pressing ok on your remote brings up the channel list but it will be in simple layout, pressing the red button takes you to detail, now if your list don't appear to be categorised you will need to press the SAT button on the remote and you need to select cable at the bottom of the list this will then give you the categories, to change each section you simply use your left or right arrow buttons.
  • satsmo
    • 6397
    LAN ONLY COMBO
    THIS IS FOR THE LAN, (STB WITH ETHERNET PORT), BOX ONLY THIS FILE WILL KILL A NON LAN BOX YOU HAVE BEEN WARNED AS THEY ARE NOT COMPATIBLE.
    Readme:
    THIS IS FOR LAN 1214 BOX
    DO NOT LOAD THIS FILE ON A NON LAN BOX OR IT WILL KILL YOUR BOX YOU HAVE BEEN WARNED !!!!!!
    NON LAN BOX IS THE BOX THAT DOES NOT HAVE A RS232 CONNECTOR ON THE BACK OF THE UNIT THIS WAS THE FIRST BATCH OF 500 SOLD !!!!
    Load grooverider file on to your usb memory stick,make sure power is off on machine and insert the memory stick into the front usb socket
    you now need to scan your channels,
    The symbol rate determines your area for example ntl is 6887, the other numbers are 6952 for telecast and EXc&w.
    once the scan has finished go to menu then highlight accessory and on the remote press the numbers "8989"
    you will then see "keyedit" appear on the right hand side, go to it and press ok and just check that auto update is on if its off just turn it on.
    Then go to to your channels by exiting the menu and pressing ok..
    PLEASE NOTE IT CAN TAKE UPTO 5 MINUTES TO UPDATE
    Channel list..
    all your channels are categorised by
    GOOD LUCK
    GrOOvErIDer
    For Sat set please look at end of readme Click Here
    NOTE UPDATED FILES BELOW:
    • manazero786
      i am still trying got same problem
      • satsmo
        • 6397
        Trying what???
        • bjorn
          • 11
          Just posting to give me access to download the latest software for the starview HD, have tried the file marked grove rider but majority of channels are still scrambled.
          • satsmo
            • 6397
            More here than downloads take a look around, starting with the differences between the two files above.
            • mark8393
              • 2305
              Originally posted by bjorn
              they will be, just follow instructions, as long as right firmware is loaded.
              • Jambo44
                - 7Days EPG update every area.
                - Update Scan/channel List menu issue.
                - USB menu update.
                - Video Output setting update ("HDMI + YPbPr + CVBS", "RGB SCART")
                - Satellite scan update.
                Firmware and full instructions for cable and sat can be found here Digital Kaos - Downloads - Starview HD Combo LAN Firmware
                Thanks for your help. I'm sorted.
                • dazwigan
                  • 15
                  hi quick question . is ther any fix for the channel auto sort or 1 available soon for the starview hd combo ?
                  • bill4676
                    • 74
                    hi am looking on buying a hd combo box but will i get all channels from sky like i do with my starview supper box on vm cable or do i need a card to view the sky channles or is it patched with the firmwire to recieve all satilite channles with out having to subcribe to sky to watch
                    • lincsat
                      • 1228
                      Not sure how much EPG you will get on Satellite, unlike cable, most non-official boxes only get Now & Next.
                      • Voyageur
                        Many thanks for this - I've just joined, because I've bought one of these (in addition to existing Kryptview and ITGate), to get HD and LAN - it all seems a bit daunting, but here goes!
                        • jugulator
                          • 26
                          First post.. Just ordered a Combo HD box. First time trying anything like this. Hope everything goes fine..! thanks for great info..
                          • cactikid
                            • 12017
                            always read up and ask before flashing before you brick it,newer box has ethernet/lan connection so needs that file.
                            • jugulator
                              • 26
                              thanks for the response. I have ordered the one with LAN. I have downloaded the corresponding file.
