Starview HD Combo LAN & NON LAN STBs
  • sd006d8688
    #271
    starveiw combo
    please help loading firmware grooverider lan 20% check memory on usb go to save data it loads but i cant get 8989
    • satsmo
      • 6397
      #272
      Download firmware again, making sure you have the correct one, i.e. LAN+ or serial only.
      Factory reset, reflash, and follow instructions on page 1.
      • obibatk
        • 7
        #273
        I have flashed my combo box with the file that includes the Cccam Fix.
        Please can anyone help me to activate/connect with this Cccam file.
        • sd006d8688
          #274
          thankyou will try when iget home from work
          • anil86
            • 4
            #275
            hi guys can somebody tell me if this new firmware is working?
            • 1952Mike
              • May 2010
              • 6
              #276
              Yes the new FW worked for me. I bought a combo last week, flashed it initially with old carling FW and id not work for me. I flashed it again with New FW and working OK One thing to note I had to disconnent my splitter and put cable straight into box then scanned When finished scanning I connected my splitter again and connected lan and it worked after a few minutes First tried scanning with splitter and although it D/L all channels it did not unscramble them so make sure no splitters are on your cable when scanning. Hope this helps
              • alex123
                • 832
                #277
                its a comman problem use an older flash first and will go in then reflash with latest firmware
                • 1952Mike
                  • May 2010
                  • 6
                  #278
                  Does Anybody know how to set up the Satellite side of things on the HD Combo my cable side works a treat but cannot get anything on the Satellite side I understand that I cannot get S*y, not even their FTA but can I get any other channels/ other Satellites?. I have a S*y Dish so can I use this or do I have to adjust this or can this pick up other satellites There are just too many options and setting on the menu so if anyone has got some setting I could use to scan for some channels would be appreciated I am happy to receive FTA and any HD channels if thats possible
                  • sd006d8688
                    #279
                    cheers satsmo worked a treat got n3 on its way now ? new card delivered::
                    • jkwel999
                      • Apr 2010
                      • 20
                      #280
                      mac
                      Hi Guys. Need some help. Have a HD combo + lan. my MAC address which has changed to 0A:00:00:00:00:00 and i can not change it back to what it should be I would like to go back to a previous fimware and change the MAC. Have tried numerous times but have been unable to roll back. If anyone has any advice as to what i should do, it would be much appreciated
                      • satsmo
                        • 6397
                        #281
                        I have updated the FW links on page 1 of this thread. It now includes a patch to fix the 206 error.
                        • jkwel999
                          • Apr 2010
                          • 20
                          #282
                          try updated link did not work says mac error
                          • satsmo
                            • 6397
                            #283
                            Was it this link Digital Kaos - Downloads - LAN+ Combo CARLING-1.00_0529_error(206)fix.uad if so factory reset, flash with the 528 file and then flash the 529 flash after again.
                            Factory reset once more and follow the guide on page one. After that you will need to speak to your supplier if it is still not registering.
                            • nick112
                              • May 2010
                              Do you have to connect to the net to get these working with the new FW?
                              • jkwel999
                                • Apr 2010
                                • 20
                                #285
                                i will have a go
