Hi Jok
I purchaced the RS232 Converter from jtags4all just follow the link and you'll see the details, it's specifically for the 8882 fix.
When you look at the link the owner of the site does say it's specifically for the 8882 fix and not for the modem unless you use a specific cable, this is what is says on the website: "This will only do Modems if you get the required lead, E.G. Ambit and you must also use a null modem cable, otherwise it will not work with modems"
I am not sure, but I am suspecting the converter, though I have contacted them and he has said to be all circuits are tested before dispatch.
Thanks,
Z
Thanks,
Z
