The Box Super USB
  • bbrc
    • Sep 2009
    • 7
    The Box Super USB
    I've just lost a load of channels off my box and reloading the firmware (tried 1.07 and 1.12) has'nt cured it. has anybody else experienced this? any suggestions how to sort it?
  • bigfella
    • 879
    Originally posted by bbrc
    do a factory reset no need to reflash just got ot factory rest on remote code 0000 then choose english ..choose ur local cable provider resacn goto sly sports and wait for update ....dont forget to goto secret cas menu 1570 on remote and open keycode on and turn default on
    • bbrc
      • Sep 2009
      • 7
      thanks for the reply and info Bigfella,
      unfortunately i've done as you've said a couple of times and i still cant access my usual channels.
      Any other suggestions?
      • gerald5445
        • Sep 2009
        • 143
        [QUOTE=bigfella;427387]do a factory reset no need to reflash just got ot factory rest on remote code 0000 then choose english ..choose ur local cable provider resacn goto sly sports and wait for update ....dont forget to goto secret cas menu 1570 on remote and open keycode on and turn default on i am trying this now cheers worked
        • bigfella
          • 879
          where do u live ? if u live in either ireland or leeds u r knackered cos nag 3 is out ..the new enscription from virmin.....if not are u sure u are turnin the keycode back on and pressin default?
          • cactikid
            • 12017
            if any cable splitters are fitted remove first before scanning.
            • john8470
              • Aug 2009
              • 6
              lost channels
              Hi i also have lost a few channels and so have family, i live in glasgow and have lost channel stv channel 4 and a few other ones like film four.
              Did you get it sorted and if yes what did you do
              • bbrc
                • Sep 2009
                • 7
                I have tried and tried again the procedure above but still no good, I am in Keighley, about 30 miles from leeds could this be the nag3 problem?
                • boomer39
                  • 2818
                  has this just happened?? it could be a local vermin problem if it affects other people as well!
                  YNWA..
                  • smoggy
                    • Apr 2009
                    • 12808
                    in the last week a few channels have been moved to different frequencies in Glasgow
                    the easiest solution is to do a factory default reset and scan
                    • john8470
                      • Aug 2009
                      • 6
                      Channels turned off around 4 days ago
                      • john8470
                        • Aug 2009
                        • 6
                        thank you
                        thanks SMOGGY worked a dream
                        • zetec316
                          I lost a few channels in edinboro area! But factory reset cured it thanks
                          • gerald5445
                            • Sep 2009
                            • 143
                            [QUOTE=smoggy;431644]in the last week a few channels have been moved to different frequencies in Glasgow
                            • greyzo77
                              Hi Guys
                              Just upgraded to Starview 5. Hows do I go about getting some channels on to this one??
                              Greyzo
