Teesside channel file for STarview The Box
  • smoggy
    • Apr 2009
    • 12811
    latest channel file after changes 22/02/10 done on a Starview2 (The Box)
    the file is not sorted apart from being in alphabetical order
  • beammill
    • Feb 2010
    • 8
    lost all channels on my the box super just did a rescan now all the channels are all over the shop with different channel numbers but still got all the channels teesside area
    • larryoke
      • 404
      If you factory reset then scan with no splitters they should come back as normal.
      • Parkless23
        Channel Dump for Starview Teesside
        Hi Guy's,
        I can not get access to this dump, can you please tell me how I can get it?
        You help is much appriceted
        Thanks in advance
        Pete
        • Hawk13
          • 10
          teesider
          Thanks for the link Smoggy......but.
          I have the box (starview 2) and have factory reset it to no avail,it only finds tv9 type channels and nowt else.
          I take it i need to get this file to the box but have no clue how too !
          • smoggy
            • Apr 2009
            • 12811
            first off make sure when you scan you scan on the NTL cable network
            menu/installation/ok/cable network NTL/automatic scan
            if you need to put above file to your box then you do it using the gtrom v4.03 loader
            • Hawk13
              • 10
              Dont suppose there a link to point me to on a desription of how to/tutorial ?
              Looking at the comm port on the back of the box,my new pc hasnt the same connection.
              thx in advance
              • smoggy
                • Apr 2009
                • 12811
                you will need a null modem cable and usb to rs232 adaptor I think your best bet will be to do the factory default reset and rescan
                • Hawk13
                  • 10
                  Ok thanks for the help..much appreciated.
                  I have tried factory reset/system/parental/i 2007/emu -on/exit/full auto scan on NTL and all i recieve is tv 6 type channels that are either scrambled or blank,i dont own a serial to usb cabl so have ordered one and then will try to update it .
                  Seeing as others are still recieving channels in my area i can only hope its this file i need.
                  will let you no when i get around to doing it
                  • smoggy
                    • Apr 2009
                    • 12811
                    was this box unscrambling channels previously
                    what does it say in system information
                    the method you used to get into emu screen is for the starview pvr unless you meant Info 2004
                    easiest way to get into the cas screen is Menu/1570
                    when you turn emu on also set default key before exiting out.
                    • cactikid
                      • 12017
                      t channels is a signal issue,factory reset coaxial from box to wall,auto scan your provider and set default key and emu to on.
                      • Hawk13
                        • 10
                        At work now guys so dont no what info it says..will check...regarding the type of model i have,,it says pvr the box on the front and looking at your forum a post describes this as being a sv2,and how i described entering the menu is all it will accept (i 2007),have always had to change the codes whenever it was scrambled before but as they seem to have not changed for a while this is the first hiccup i have had.
                        • smoggy
                          • Apr 2009
                          • 12811
                          you have a Starview pvr (not a Starview 2)
                          as far as I'm aware the latest firmware for that box was december 2008
                          • Hawk13
                            • 10
                            Hmm ok thanks( i'm an idiot).
                            Well i have rescanned it anyway from the live feed with emu and other one on and get nothing now........ to the old tv remote i go
                            • boomer39
                              • 2818
                              we still dont know what f/ware is on your box!!!!
                              btw, what do you mean by "to the old tv remote i go"????
                              YNWA..
