help plz on starview combo
  • plzplz
    • Mar 2010
    • 6
    ive bought a hd combo and iam looking for the right files to put on to make it work with cable
    ive had a look but how do i tell witch 1 to download that right for my box
  • badapple
    • 2041
    Hi m8, there are two different filed, one for the LAN box and other for the NON LAN box.
    Look at the back of your combo box, if it has the LAN socket then use the lan files only.
    SLOWLY, OUR FREEDOM IS BEING ERASED.
    SOON, WE WILL JUST BE A NUMBER.
    IF WE DON'T FOLLOW, WE WILL BE ERASED.
    • plzplz
      • Mar 2010
      • 6
      but it says dont use on a box with serial mine has rs232 does that count as serial
      • badapple
        • 2041
        Dont worry about the RS232 serial socker, they both have this. Just make sure your box has the LAN ethernet socket or not.
        If you have just purchased this box new, then it will be the LAN model.
        Go by the LAN socket m8.
        • plzplz
          • Mar 2010
          • 6
          nice 1 m8 thanks u a star
          • plzplz
            • Mar 2010
            • 6
            still havin probs m8 fails when i try to update using usb
            says failed check your usb memory
            • badapple
              • 2041
              At what stage is it failing?
              You will need to install the original FTA files first and then update to the latest files.
              • plzplz
                • Mar 2010
                • 6
                were are they m8 soz about this realy new to this
                at about 20 percent
                • badapple
                  • 2041
                  Check you PM m8, help file sent.
                  • gtrom man
                    • Mar 2010
                    Having a problem with my starview 6 keeping channels store. keep on have to rescan any ideas.
                    • scousemaster
                      • 14
                      wondering if any1 can help me same things happening to as above check usb at 20 percent
                      • t4csx
                        • Apr 2010
                        • 5
                        Help Pls
                        Can you pls send me the relavant file as im having the same problems...
                        I have uploaded the firmware which has worked but i cant get the 8989 screen to come up? any suggestions my system info reads
                        System Information
                        Model Name Starview HD Combo
                        Software Version : Ver 04.03, LDR: Ver 00.21
                        Hardware Version : Ver 01.20
                        Last Update : Jan 30 2010
                        i have tried to reinstall the old f/w but it keeps crashing!
                        Any suggestions pls your help would be really appreciated
                        • ravster
                          • 16
                          I have the same problem, I fresh Starview HD Combo with LAN port, tried updating with from the advice given in satsmo post here Digital Kaos - Downloads - Feb 09 Latest Starview Combo LAN Firmware
                          Starview_HD_Combo__0128.uad
                          GrooveRider_HD_Combo__0212.uad
                          Still no joy, getting the error message "Update failed. Please check your USB memory" I've tried with a HDD and a USB disk. I've checked that the unit can read files off it firstly I can see the filenames above and secondly I can play divx files directly off both memories.
                          Any ideas?
