i have a digivox xl usb which i believe is starview , my box went off in january and i have been trying to sort it out since to no avail , i followed steps from other forums and its getting me no were i must be doing something wrong properly the simplest thing , so sorry to trouble any one but could you help thanks
digivox xl usb need help installing sorry if this is a repeat of someone elses quest
Tags: None
the front of box says digivox xl usb
when i go on system info says
system id 32214
model code 3176
loader version L-01
soaftware version 1.01
laste update feb 24 2009Comment
is box new? if yes you have to flash latest firmware,then scan,then go menu/system info,press ok and type in 1004,turn on the emu,exit out to tv and let it update on a pay channel. if your area is n3 then its not worth botheringComment
the box isnt knew have had it about 1 and half years when i type in 1004 on system info cant see option for emu , im thinking there must be a seeting ive acidently chnaged if i do a factory default can some one send me a link to the method of the gigivox xl usbComment
did you press ok on system info? then type in 1004the box isnt knew have had it about 1 and half years when i type in 1004 on system info cant see option for emu , im thinking there must be a seeting ive acidently chnaged if i do a factory default can some one send me a link to the method of the gigivox xl usbComment
i have pressed set default key screen come up (saving ) and exited , as ive alredy pressed fac reset im re scanning for chanels will let you know what happensComment
lets hope you done it in right order,which should be factory reset first,,then scan,,,then put emu on,exit to a pay channel let it updateComment
