digivox xl usb need help installing sorry if this is a repeat of someone elses quest
  • needhelptoinstall
    • 14
    i have a digivox xl usb which i believe is starview , my box went off in january and i have been trying to sort it out since to no avail , i followed steps from other forums and its getting me no were i must be doing something wrong properly the simplest thing , so sorry to trouble any one but could you help thanks
  • cactikid
    • 12017
    read what is printed on front of unit and also tell us what firmware is on it,menu-system info-?????,as that will guide us to what box,also helps to know general location because of nagra3.
    • needhelptoinstall
      • 14
      the front of box says digivox xl usb
      when i go on system info says
      system id 32214
      model code 3176
      loader version L-01
      soaftware version 1.01
      laste update feb 24 2009
      • smoggy
        • Apr 2009
        • 12809
        you missed out some very important information
        What is your location (nearest big town)
        • needhelptoinstall
          • 14
          manchester sorry
          • smoggy
            • Apr 2009
            • 12809
            I have no exprience with digivox but what exactly are the problems, what have you done and what is happening
            • boomer39
              • 2818
              Originally posted by needhelptoinstall
              manchester sorry
              not heard of anyone local having n3 cards yet, but g/manc is abig area...
              YNWA..
              • cloudnineuk54
                • 530
                is box new? if yes you have to flash latest firmware,then scan,then go menu/system info,press ok and type in 1004,turn on the emu,exit out to tv and let it update on a pay channel. if your area is n3 then its not worth bothering
                • needhelptoinstall
                  • 14
                  the box isnt knew have had it about 1 and half years when i type in 1004 on system info cant see option for emu , im thinking there must be a seeting ive acidently chnaged if i do a factory default can some one send me a link to the method of the gigivox xl usb
                  • cloudnineuk54
                    • 530
                    did you press ok on system info? then type in 1004
                    • needhelptoinstall
                      • 14
                      yes i will ell you options that come up
                      nagravision ok
                      set default key
                      keycode enable
                      • cloudnineuk54
                        • 530
                        nagravision ok
                        set default key
                        keycode enable
                        leave nagravision alone,ok on set default key,itll just flash,then make sure keycodes enabled.exit out to tv and let it update
                        • needhelptoinstall
                          • 14
                          i have pressed set default key screen come up (saving ) and exited , as ive alredy pressed fac reset im re scanning for chanels will let you know what happens
                          • cloudnineuk54
                            • 530
                            lets hope you done it in right order,which should be factory reset first,,then scan,,,then put emu on,exit to a pay channel let it update
                            • needhelptoinstall
                              • 14
                              when i leave on chanel to update screen just stays blank and does update
