How to Manually update keys on Starview
  • tony_i
    • Oct 2008
    • 425
    #31
    Originally posted by tony_i
    I seem to be missing something.
    I go to the nagra part of my SV4, change the code to suit my provider (CW).
    Change code 0, press OK to save. It says it's saving it.
    Do the same for code 1.
    Exit.
    Channels say they're updating but aren't.
    I go back to nagra and my new codes have all disappeared.
    Help!
    Tony
    Someone just posted this on another thread:
    "Just been reading on another forum that the C+W keys on keymaster are incorrect and so we have to wait for new ones. This would explain my difficulties> Can anyone else add anymore to this?"
    Could this be my prob? Still doesn't explain why my settings aren't being stored.
    • mickarick
      • 107
      #32
      Originally posted by satsmo
      Mick, press menu - type 1570 on remote - press default key - then select provider - now input both key lines.
      Didnt work sorry m8 tried both lines same as before when box fails to update i go back to nargra and its still goes back to nthell
      • tony_i
        • Oct 2008
        • 425
        #33
        This seems similar to the problem I'm having.
        • nsw9154
          • 259
          #34
          my box pvr went off today as well but is dose not use the 1570 code it uses a diferent set up will this fix work with the box pvr
          • satsmo
            • 6397
            #35
            Mick select default key again, then turn SV off at back switch then back on. Now see if you can enter codes on the correct provider.
            • satsmo
              • 6397
              #36
              Similar except:
              Go to parental control in receiver menu
              press ( i or info button) + (2007)
              key screen will be visible
              • scozzer
                #37
                hopefully this will work
                • The Cobra
                  • 14
                  #38
                  Av also got The Box and yep you can get into the secret menu thru the parental controls bit as described above, gona try and sort this out in a mo I hope we can all get this back working soon enough!
                  • mickarick
                    • 107
                    #39
                    Does anyone know how to switch the auto update off on the box please
                    • jordanjoel
                      • 38
                      #40
                      sorry guys to be a pain, have tried all afternoon to open keymaster have even downloaded winrar, is there any other way to get keymaster codes for my starview 3 please?
                      • satsmo
                        • 6397
                        #41
                        Turn key emu off in CAS menu, where the default key is.
                        • mickarick
                          • 107
                          #42
                          Ahhh but then i wouldnt get ppv channels would i ohh well just a thought , thanks m8 .
                          • tony_i
                            • Oct 2008
                            • 425
                            #43
                            Cancelled post.
                            • nsw9154
                              • 259
                              #44
                              i am getting realy confused and not sure what to enter i got into the nagravision page
                              provider id 54 01 00 NTL
                              key number 00
                              so i changed the key number to 02 it did not work and always seems to reset back to default so i tried 54 01 02 still the same 54 02 02 still will not work what am i doing wrong thanks in advance
                              • satsmo
                                • 6397
                                #45
                                If you are on NTL you dont change the provider ID, you change the 00 and 01 key lines.
