replacing starviews?
  • parley
    • 106
    Hi guys I have had a good look round and i am still as confused about this, hopefully someone can give me some good advice. My two sons starview boxes died a couple of weeks ago, and i am looking to replace them. I don't want a dish, at the moment i have an internet connection and a router in one of the rooms upstairs, and hopefully the new boxes will be of the same price range, up to ?150. So please can someone recommend me a good replacement, any help will be greatly appreciated, thanks.
  • Tech54
    • 72
    You have a choice of either Starview 6 or 7, or Kryptview a780 they all connect via Lan/internet
    Check out prices and see whats available, I know the KV's are scarce at the moment.
    Hope this helps
    • parley
      • 106
      thanks tech54, had a look at both of these, read somewhere starview will probably last 12 months, i know the kryptviews are scarce, but if i did manage to get one are they a cs machine or more like a starview type but using a LAN?
      • Tech54
        • 72
        They all connect to servers via Lan and cable. I have the KV A780, works very well. You can read up through the Tutorials under each section they are very informative.
        Heard the SV's are only good for 12 months.
          I keep hearing that starview will last 12 months who brought this rumours in the first place 12 months from what date we had starview6 in Ireland for over 12 months and now starview7 is hear and 6 is still working 8 is out mid April 2011 and to understand how this boxes are working before you jump on the wagon they work with the server and as long as the server will be running all LAN starview will be working if the server stops today that?s the end of it no guarantee I wish some one will give me 12 months guarantee I will be the first person to get a contract
          • parley
            • 106
            after a bit more reading i read that you need a cable feed to run th KV A780 i only have broadband, which ran my starviews, are there any other options available that just need a broadband feed?
            • parley
              • 106
              Originally posted by JoK
              If you ran starviews then you have the cable feed you need for the kv.
              Plus an ethernet connection to your router, be it a long cable run or using homeplugs.
              JoK
              I ran my starviews from my broadband feed, i do not have cable tv coming into the house will the broadnand feed plus the ethernet connection to router run the KV?
              • calverley
                • 74
                my star view just had cable feed after down load softwear via rs22 lead
                • parley
                  • 106
                  not sure if i'm missing something here, i took "cable feed" as being a cable tv lead coming into the house, or does it mean an actual cable, i'm getting more confused.
                  can anyone post exactly what is needed to run a KVA780 thanks.
                    The cable feed into the box and an ethernet lead connected to your router.
                    • parley
                      • 106
                      The cable feed into your house is the same for BB or TV they just use a splitter to feed TV and modem.
                      So if you just have BB with them but no TV package then it will work fine, you have been using it to run starviews
                      So connections will be same as before with your starview plus an ethernet connection.
                      JoK
                      Thanks jok thats just the explanation i was after.
