New Firmware Starview 3 - 8.04e
  • baraji
    • 4
    #331
    WHATS IS METHOD TO UPLOAD OR UPDATE STAERVIEW 3 THE BOX PLEASE?
    • vickib1986
      Originally posted by blairco
      Digital Kaos - Downloads - GTRom_Super_8.04e.exe
      The new firmware for starview 3!
      thanks for this x
      • meralto
        • 13
        #333
        help
        I have a starview 3.....
        love S*Y sprts 1 and 3 and other channels on the 747000mhz frequency......
        any ideas how to get them back? I have done fractory reset...no good....
        the only alternative it new firmware....
        ideas are very very welcome...
        Meralto
        • cactikid
          • 12017
          #334
          welcome to dk,when you scanned did you have a splitter on coaxial cable,if so remove,factory reset 0000,auto scan your provider and emu to on.
          • meralto
            • 13
            #335
            will give this a go now..
            its always (i think) 747000 mhz that give me gyp...
            im in Leicester....
            thinking of getting a konig cable tv/modem signal amplifier....recommended or not?
            again....will let you know of my result...
            M
            • meralto
              • 13
              #336
              eliminated the splitter....
              did factory reset....rescanned....turned EMu key on...went to a channel i know that works....data updated...
              but still no s*y sprt 1,3, Nat Geo...and playboy...but not bothered about the latter ...
              you reckon the node is down for 474000mhz or im just being damn unlucky...
              I have also tried a manual scan on that freq and got jack in return...
              spken to a friend of mine and he thinks my signal is weak....yet my 10mb b/band is a-ok..... (and yes i did turn off modem when i rescanned)
              scratching my head furiously now...
              any more suggestions??
              • boomer39
                • 2818
                #337
                try pressing default after turning emu on, then exit..also try another provider...
                YNWA..
                • meralto
                  • 13
                  #338
                  tried the default key option...
                  its just doesnt want to scan the 747000 channel...
                  will another provider work considering its only ever been ntl/virgin in this area?
                    said this before some times you have to rescan a few times to get all your channels back..
                    • meralto
                      • 13
                      #340
                      tried the diff providers.....this is the 8th scan of this evening....beginning to give up on this thing...been a good run tho...
                      need to grab a serial cable fomr work to flash with new firmware....
                      while scanning... it gets to TP56: 747000/6887 which gets a result of failed....
                      also noticed with each scan...it finds fewer channels....
                      any other thoughts?
                        what is the firmware on the box at present? if your getting sly sports 2 and other premium channels you dont need to flash the box. plus where are you from?
                        • meralto
                          • 13
                          #342
                          in system info it says:
                          THE BOX Super,
                          API ver: 802e_E,
                          boot ver 8.00,
                          30 nov 2008
                          I can all the channels i watch except the 2 sports and nat geo
                          Im in Leicester....this was fine till yesterday....had the pool Vs gunners game on....left the room..c.ame back for a smoke and got 'no signal' msg on screen....been screwed since then....
                            try switching the box on and off a few times from the back and then rescan..
                            • meralto
                              • 13
                              #344
                              tried that a few times......
                              • cactikid
                                • 12017
                                #345
                                or it may be as simple as tps off line and waiting for repair,then you may get them back after a day or so.is that the latest firmware or is there a newer one?? v8.04
