starview7 newbie no channels
  • vrsix0121
    • Feb 2010
    • 4
    hi all ive installed latest firmware and my starview7 isnt piking up any channels can any1 help me out thanks
  • slobojoe1
    • 33
    have you done a rescan.
    • vrsix0121
      • Feb 2010
      • 4
      ye ive rescanned it on auto and tried all the other numbers im conneted to net ive tried installing the earlier firmware and putting the latest 1 back in im just a little lost with wot 2 do next if any1 can help thanks
      • slobojoe1
        • 33
        is it finding any channels. or is it just not saving them. have you had it up and running on previous firmware.
        • vrsix0121
          • Feb 2010
          • 4
          i bought it yesterday ive never had it running and its not picking any channels tv or radio ones it takes ages to scan but at the end always 0 channels
          • smoggy
            • Apr 2009
            • 12808
            I take it you do have a VM cable tv feed plugged in and that feed is live
            • ByteMaster
              • 203
              First of all are you a paying cable customer?
              If yes is your subbed box working.
              Ensure you put the cable feed into the box.
              Go into the menu/installation/Auto.
              Set your symbol rate for your area.
              Scan using all or free/scrambled.
              Once that is complete you should have some if not all channels.
              Exit out completely to a channel.
              Power down box for a few seconds and reboot.
              Below is availanle on the HD Combo so I am assuming the SV7 is similar.
              Next.......
              Go back into menu/Installation/Manual scan.
              Select a frequency that is showing a signal and now select network scan then hit the scan button.
              This will take approx 15 mins and should now populate any missing channels.
              If all above fails you either have been disconnected outside and have no live cable feed coming in, your symbol rate is wrong or worse still a faulty box.
              Once upon a time it was all about backdoor 0 passwords, now its only about the rsa keys !!!!!!!
              If this post has helped you........... Don't be shy and hit the Thanks button..
              • jay27mcr
                • Apr 2009
                • 7
                check your connection mate. Sometimes the problem can be a s simple as that.
                • zubair85
                  • 5
                  can some one help me? I have starview 7. I had bought it a while ago with it already working but then it stopped.
                  I belive there is a new firmware. can you tell me what to do with this firmware.
                  obviously you download it on to a usb and connect it to the staview, how and where do i upload this new firware on the staview
