hi guys, newbie to this scene. my starview 7 box that i bought last week has scrambled channels except the normal tv stations. i have downloaded carling v1.04 onto usb and installed but still have scrambled channels. cheers gaz.
starview 7
Tags: None
u connected to the router ?any information provided is for educational/experimental purposes only. -
reboot both and leave on sky sports one for 5 minutesany information provided is for educational/experimental purposes only.Comment
Digital Kaos - Downloads - Starview 7 Carling V1.04
If you ever need firmware look at top of page; DOWNLOADSComment
They work when connected to TV cable connection & internet
They sell for around ?100 & you set them up yourself. If you buy
already set up you are going to pay more for the privilegeComment
yes she said was a 100 and 30 quid for the software is it has easy to do as the the box super which i had b4Comment
starview7 and using splitter
Hi all - please be gentle - new to digital kaos!
so i have a box and i've set everything up like this:
1. main v line into splitter then one cable into modem and the other into starview 7 (CABLE IN)
2. cable from modem ethernet to wireless router internet
3. cable from wireless router LAN to Starview 7 (RS232)
4. Then of course scart in starview 7.
My box worked yesterday for 20mins and then the internet connection went? Tried checking all connections etc and still no connection.
I am using a splitter so i tested to see whether i have a internet connection problem but when i took off the splitter and connected the v**** line directly to my modem i had internet connection.
I'm a little baffled as to why it worked and then suddenly now i have no connection through the splitter??
Do you think i need a new splitter as it is a old one since it worked fine? Perhaps the splitter isn't 'strong' enough to pass the connectivity to both? (complete rookie chat here as you can tell!!!)Comment
First make sure all cables & connections are perfect. Check theHi all - please be gentle - new to digital kaos!
inner core of co-axial v***** cables is not in contact with outer
braid. Then turn off router & box, reboot router then reboot box.
If you need to replace splitter look for F-type(screw on) type with TAP connection If you can. They are better than regular
splitter when supplying modem & TV connectionComment
