iphone underwater !!!
  • cablefreejunkie
    • 1717
    my mrs dropped her i phone into a bath yesterday,,obviously it now wont switch on and the screen looks funny round the edges
    is it completely ~~~~ed or can this be brought back to life ?
    The control of information is the consolidation of power
    ?I care not what puppet is placed on the throne of England to rule the Empire. The man who controls Britain?s money supply controls the British Empire and I control the British money supply.? ? Nathan Rothschild
    IF I HELPED HIT THE THANKS BUTTON
  • sotarn
    • Jul 2011
    Dry
    Just release the battery, and dry it for a long time until try to start it up again.. then if you are lucky....
    • cactikid
      • 12017
      even use some of that moisture absorbent stuff to draw it out of phone leave it for a number of days before use with back off phone,tell her next time to play with rubber duck they float
      ,remove battery sim and sd card if fitted.
      • Rodbouy
        • Jul 2010
        • 1320
        put it in a bag of rice to draw out the moisture, but if you have turned it on before it fully dried you could have goosed it.
        • RedSpider
          • 2448
          daft cow.
          what app had she installed that she thought it would be safe to use in the bath?
          Syntax Error : Integer Out Of Range
          Hooray For Tits & Fannies
          • cablefreejunkie
            • 1717
            how do i release the battery ? its a 3gs
            • cablefreejunkie
              • 1717
              Originally posted by RedSpider
              daft cow.
              underwater app free in app store
              • gopher7
                • Apr 2011
                • 2818
                As Rodbouy says, leave it in a bag of rice for 3 - 4 days, hopefully it will work, if not it's prob knackered.
                • RedSpider
                  • 2448
                  1. ~~~~ iphone in bin
                  2. buy android
                  3. don't let missus touch android
                  • dagas
                    • Jul 2011
                    i don't think that it is going to work....
                    try to dry it.
                    • smirnoff_rules
                      • 8603
                      remove screen and use a hairdryer on board
                      • opsmonkey
                        • 5379
                        i had mine on a coach seat and my water bottle fell on it and dripped on it while i slept for 3 hours.. had to remove the little screws and open it up.. left it in the airing cupboard for 1 week.. worked fine..
                        [ame=http://www.youtube.com/watch?v=kQmznXvQmuY]‪How to CORRECTLY open up your iPhone 3G/3GS or iPod Touch using a Suction Cup - Disassembly‬‏ - YouTube[/ame]
                        • Canker_Canison
                          • 3904
                          Remove the two screws from the bottom
                          Using a small suction cup, pull the screen away from the phone close to the home button.
                          Disconnect the LCD, digitizer & earpiece connectors. The earpiece is the last to be removed & you have to be careful not to damage the connector.
                          You will need to remove the main board. There are screws holding it in place. The charge port at the bottom is a little tricky.
                          Once removed you need take off the metal covers on the board. Lightly scrub the board with IPA using a toothbrush (the wifes will do). You can also submerge it in a bath of IPA.
                          Once all trace of the water has been removed dry it with a hair dryer & put it back together.
                          I do this at least once a week on an Iphone. The battery may need replacing, it's also possible for the charge port to stop working. Both are cheap to replace.
                          If you do need to change the charge port make sure you get the full unit & not just the ribbon.
                          Canker
                          [COLOR=Green]
                          • cablefreejunkie
                            • 1717
                            i followed the above steps and all went well,,re assembled the phone with a new battery,,charged it up etc only issue i now have is it keeps loosing coverage,,i have service and then i take a look at it 5 minutes later and ive lost service again
                            anyone got any ideas as to what might now be wrong ?
                            • cactikid
                              • 12017
                              water damage? ,did you reboot it again.?
