Tonight ramming my male part into the badly splayed female part, ended up cutting
with angle grinder to get it off, so hopefully a clamp will do, got some exhaust paste somewhere
Well tonight, got my ringpiece hot, then hammered it on the the bussness end of my shaft, had to coat my end in grease
then ring piece went cold and hard, so warmed it up, then hammered it on more, you can see the end of my ring piece has been hammered, but not got a copper/hide mallet
then flicks my shaft up and lost one of my huts in the long grass , unable to find it
then I remembered that I have more than one nut, so used that instead.
once shaft happy, I rammed it in the black hole it lives in, and locked it in its little housing, and just needs a little more screwing.
Tomorrow I’m hoping to have a good old blow in my tank, got about 35 litres of juice init.
tightened my nuts up, one slightly loose, but grab the shaft it’s attached to and solid
then ended up squirting some white sticky stuff on my undercarriage
1/2 can left, amazed how little it covers.
then ended up with a right turd, came running out one of my holes, faster than fresh shit off a greasy shovel.
will try and steam clean it off another time, most of it that went down my leg came off with white spirt
