what you doing to night.
      Originally posted by nara
      You've stopped taking the tablets again, haven't you? [ATTACH=CONFIG]637759[/ATTACH]
      yes, left some white bits in my hole.
      tesco washing machine cleaner
      TONIGHT:-
      need to to fix air line as it’s leaking too much
        Update to last night.
        was quietly playing with myself and naybours needed a hand moving sideboard, ended up cutting the legs off to get it in his house, then hacked legs off his coffee table to make it all match
          Tonight, feeling hot hot hot
          rung somebody, now classing me a a nuisance! Charming
          Off to get beer, laters
            Sleeping when got in, went to aldipish, got food, avoided somebody of lower intelligence
            now looking at pörn, then bath
              Weird friend pub
              played in rain, looks at pörn
              chocolate
              more chocolate
              bath
              bed
                Tonight, gets the tail fin, bolted on, 96 dozen bolts, turns around, looks down in the bag of bits is a small clip the size of a penny, should have gone in first.
                ripps all apart, fits said clip, refills the custard tank, custard comes dripping out the tail fin.
                takes the 96 dozen bolts out again, to find the hose that has been pressure tested has failed.
                wrapped a load of sellotape on it, 96 dozen bolts in, refilled with custard, sorted.
                Tomorrow should be able to fill the tank, using kerosene, it’s cheaper.
                  Hopefully can get the aelorons bolted on tonight, might use sellotape as it’s cheaper than correct screws.
                  not found the cranking handle yet either
                    Got the alreons bolted on, looks great now.
                    found cranking handle but end damaged
                      Sit inside tonight and just play with my self
                      might pop pop outside if no rain to cut a carbuncle down
                        Playing in garden,
                        Hoping to get the stirrups on tonight, if time the saddle as well
                          Weird friend pub
                          glueing lump of metal to another piece of metal
                            Update:-
                            glued lump imp of metal to others lump of metal, got the thin wormy thing, won’t fit in my hole
                            could grind it down, but as it’s going to be stopping things going bump in the night. I’ll get it exchanged.
                            rear pads, talk about SEIZED, I mean SEIZED, ended up destroying the old pads with a pry bar, chiesl or punch.
                              Went 500 miles, to feed a flea bitten ungrateful cat, got my fan mail
                              then 500 miles back
                                Fully interested in going to Tesco express at about 8:45 pm for cheap food, but
                                ended up sleeping in t bath
                                accidently singed imaganry cats tail, with nearly 89 deg hot water, stupid thing sits in a puddle of oil and didn’t move as steam clean d it
