traction in snow
  • accies
    • 95
    traction in snow
    Here is a tip from Norway,clean you drive axle tyres with engine degreaser,just spray them with degreaser leave a couple of minutes then wash it off or spin wheels in fresh snow,you will be amazed at the grip you then get from your tyers.It does work
  • 4dbennett
    • 99
    Thanks accies, any particular engine degreaser,
    regards dave
    Football is not a game
    It is life
    come on you gooners
    • accies
      • 95
      No any type will do just make sure to either wash it off or spin wheels in new snow,you will se all the oil etc that was on tyers,its realy is a great tip.
      • johnboy1974
        • 3418
        sounds good i will try it, sounds a good way to clean tyres even in the summer.
        • caveman_nige
          • Feb 2008
          • 4920
          does this damage the tyre rubber, not keen on shortening the life on my tyres as they weren't cheap...? wish i could switch the traction control off to spin the ~~~~ers as well...
          • smirnoff_rules
            • 8603
            cant u just turn your esp {Electronic Skip Protection}off like every one else m8 / its more trouble than its worth
            • caveman_nige
              • Feb 2008
              • 4920
              wish i could mate, but my car is one with the button that does nothing,, have been unable to switch it off....
              • cactikid
                • 12017
                if its petroleum based i would be worried as in rotting rubber,a good hose down afterwards needed as you dont leave it on too long.
                • smirnoff_rules
                  • 8603
                  ? l was sure ever car has the option to turn off m8 .. do u have to turn off before u start .. wot car is it
                  • melloned
                    • 1215
                    Got out of bed 6.00am Tuesday , popped my head out of the door , every car 18-20cm deep in snow , attempted to drive my 12 mile journey to work , but within 1/4 mile saw 2 cars buried into each other and thought , stuff that ! , turned around , went home and took the dogs out for a 2hr walk through a local woods , Lovely !.
                    The police are still saying drive in emergencies only , so until they say otherwise i'm doing just that !
                    Far nicer having a dog walk in a winter wonderland ,than mangling your car !
                    • caveman_nige
                      • Feb 2008
                      • 4920
                      its a facelift signum elite turbo. have looked into it and it seems that its a common issue..
                      i have a can of Lidl engine cleaner hanging about , an curious about trying this 2moro morn.. but am worried about trashing my new Sessantas.. In norway they use studded winter tyres anyway don't they... I only need to get to the motorway about 2 miles away and it will be clear (i hope)... if i don't get it then like may others i can't invoice for the day and i kinda need the dosh as my CT is due to be paid at the end of the month...
                      • cactikid
                        • 12017
                        another tip have a battery/cigar lighter tyre guage pump in car ,some people deflate tyres down to 20 psi which gives more tyre contact to road for more grip.
                        • chroma
                          • 1976
                          i just use bleach on my tires in the winter to remove all ice, snow, gunk and oil.
                          He who laughs last thinks slowest.
                          • zak101
                            • Aug 2009
                            • 49
                            I prefer mi navara
                            • caveman_nige
                              • Feb 2008
                              • 4920
                              well i tried that engine degreaser trick this morning, am not sure if it helped as i had nothing to compare it against, but i managed to get into work anyway.. i guess anything that helps is worth a go..
