anybody no how to make a 3g outdoor antenna
    ive tried google and found some dodgy efforts at them
    there quiet pricey to buy thats why i want to give it a go making one
    but im good with my hands so there will be no hassle making one once ive got a good idea of one
    this is the 3g router i have
    EnGenius 3G Router NET-3G-ESR-6650
    ive found this antenna on the net its very cheap but its frequency band doent suit i think
    im not up on this kind of thing so correct me if im wrong an il buy it
    DealExtreme: $15.56 1990~2170MHz 12dBi Directional High Gain 10-Unit Antenna for 3G WWAN Network (N Female)
    thanks if anyone can help il take lots of pics of it an il write a good step by step for making on for anyone else that might want to make one
  • zorgman
    • 45
    ive usedan old zone 1 sky dish with a usb dongle to get a signal from a macdonalds for y mate worked mint just tape it onto lnb front as thats the focal point and point it in the correct direction
    • Canker_Canison
      • 3905
      You're right, the frequency of the antenna doesn't go high enough. It should still work...but you will lose a lot of the power gain.
      I have an old dish that was going to be used to boost my wi-fi. Never got round to fitting it... might try harder, later.
      Canker
      [COLOR=Green]
        in what way would it affect it then
        if it made just a bit of an improvement id be happy for the price like
        • hersman
          • Nov 2010
          Good idea
          Can't say that I do, but sounds like a good idea
          • thewizardofodds
            • 924
            Homemade equipment for 3G
            • Canker_Canison
              • 3905
              I have some disturbing news.
              I checked this over with he who knows so much, my dad. If you use an antenna that isn't correctly tuned you will be running the risk of burning out the transmit amp from the dongle.
              If you go with the tiny little external antenna, as in the wizardofodds post, with a parabolic dish. You should see far better results.
              He did come up with another solution, but this will need a small amout of research & some hardware.
              In short, you can make a yagi stye antenna on a PCB board. Draw your design on the PCB, coat it, then dip it in the acid to leave your design on the PCB. Solder your connecting wires onto the pickup bar & away you go.
              This system is already used on bluetooth & wifi devices so it does work. You will just be making it bigger.
              Canker
              [COLOR=Green]
                dAMM CAPS LOCK - Sorry, just too lasy to bend down and grab my dongle, Hauarni E661? - no idea - if you wench it open has an smd connector on the board to connect a standard internal cartype areail to!
                Just download one off ebay
                T-BAR GLASS MOUNT AERIAL Antenna for GSM Car Phones on eBay (end time 12-Dec-10 20:05:51 GMT)
                The last time we sold these 12+VAt
                • lord peter haylor
                  • Nov 2010
                  • 11
                  WiFi Aerials
                  There are several disigns for WiFi aerials on the Internet,One of the favorite is to use a "pringles" tube, yes the crisp tube!
                  Biggest problem with all of then is the need to be accurate with the holes and measurements of the elements as a small error will make a large loss of signall
                  Easiest way is to use an old Sky dish and a USB wireless stick as already mensioned.
                  • Canker_Canison
                    • 3905
                    It's not the wi-fi that needs boosting, it's the 3G dongle.
                    The problem with the use of a sky dish is that it isn't parabolic. The dish is setup for receiving, but not transmitting. Yes, it will work...but you still run the risk of damaging the transmitter on the wi-fi dongle.
                    The most successful designs use things like sieves & colanders as these are parabolic.
                    Canker
                    [COLOR=Green]
                    • thewizardofodds
                      • 924
                      Think people actually put the dongle on the lmb to get a better reception as opposed to plugging the dih into the dongle antenna connection
                      • Canker_Canison
                        • 3905
                        Here's some heavy reading made sightly easier on parabolic dishes & tuning. This is for Ham radio so the data would need amending for 3G signals.
                        qsl.net/n1bwt/chap4.pdf
                        Canker
                        [COLOR=Green]
                          turns out i cant connect an antenna to my router so im ive bought a 10m usb cable an im going to stick the dongle on the roof in a sealed box to see if it helps thanks every1 for the help
                            wow word on street says limited to 5 meters!
                              ~~~~ it ordered a 10 m one
                              sure there not expensive the 5m might be a bit short to reach the roof but il give it a go anyway since its probably half way here already from china
