Forgot pattern lock
This topic is closed.
  • alfatah78
    • Oct 2017
    • 40
    Forgot pattern lock
    Dear concerned member, i need help with techno android spark 3 pattern unlock. Actually forgot new pattern used. Thanks
  • aliliabdelbasse
    • Nov 2019
    Tecno Spark 3 hard rest
    All methods of Hard Reset operation in your device. Read our tutorials and Wipe Data on your device. The Factor Reset operation will erase all personal data, customized settings and installed apps. It could be also the only way to Bypass password, pattern or fingerprint.
    • veraP
      • Nov 2019
      • 13
      You can easily set new pattern by tapping the "Forgotten Pattern" and proving the gmail credentials associated with your device.If not you can use Switch your phone off > press and hold the volume up + the power button at once to boot into recovery mode > select wipe data using volume keys > Select "Yes" using Menu button > press “reboot now”
      • toyota123
        • Sep 2019
        • 440
        use odin new version
        DON'T FORGET TO USE BUTTONS BELOW REP & THANKS
        • nbtechnic
          • Jan 2016
          • 321
          Odin 3.14.4 is the latest version and it is fully compatible with the latest UI 3.0+ (Android 11) and older versions of One UI (Android 9.0 Pie) ...
