Dear concerned member, i need help with techno android spark 3 pattern unlock. Actually forgot new pattern used. Thanks
Forgot pattern lock
This topic is closed.
You can easily set new pattern by tapping the "Forgotten Pattern" and proving the gmail credentials associated with your device.If not you can use Switch your phone off > press and hold the volume up + the power button at once to boot into recovery mode > select wipe data using volume keys > Select "Yes" using Menu button > press “reboot now”Comment
