unable to upgrade to ios 5
  • fijiman
    • Oct 2010
    • 976
    #16
    Originally posted by cablefreejunkie
    ive deleted the apple entrys but still keep getting error 21 when trying to update,ive tried all the suggested alternatives but cannot update
    im stuck help me pls
    You need administrator rights to make changes in host files....
    Easy way would be to run tinyumbrella>Advanced tab>uncheck Set host to Cydia on exit.>close tinyumbrella.
    You should be able to do a clean install..
    • cablefreejunkie
      • 1717
      #17
      excellent info fijiman,im now on ios 5 and jailbroken,,easiest one yet,must be learning something
      thanks once again for your help
      The control of information is the consolidation of power
      ?I care not what puppet is placed on the throne of England to rule the Empire. The man who controls Britain?s money supply controls the British Empire and I control the British money supply.? ? Nathan Rothschild
      IF I HELPED HIT THE THANKS BUTTON
      • cablefreejunkie
        • 1717
        #18
        my jailbreak went ok,cydia installed etc,started loading up various essential tweaks,then loaded app sync 5 phone rebooted now i dont have cydia ,,,anyone know why ? cant find it anywhere
        ive got no settings tab either
        • dik
          • Apr 2009
          • 955
          #19
          Try a hard reset, if no joy re jailbreak
          sigpic another happy customer
          Sent from my keyboard using fingers to type
          • cablefreejunkie
            • 1717
            #20
            tried to re break but redsnow kept failing,after 2 times phone booted up and everything was there again,very strange,,now whilst trying to install a tweak,upon rebooting im now stuck with the apple logo on the screen and cant do a thing
            what state is the phone in now when you have the apple logo stuck on the screen ?
            • dell_xps
              • 2558
              #21
              Try tiny umbrella to boot it out of recovery mode m8.
              • cablefreejunkie
                • 1717
                #22
                when i run tiny umbrella that option is not available
                • dik
                  • Apr 2009
                  • 955
                  #23
                  Do a hard reset, press and hold power and home button till you get a flash on the screen
                  • cablefreejunkie
                    • 1717
                    #24
                    tried that but no flash,logo goes off then back on again,tried to rebreak but redsnow recognises a device in dfu,it then shows i tunes and a cable logo,then i try with tiny umbrella again and fix recovery mode is available but dosent work,gonna keep trying for a bit
                    • stevieboy10
                      • 137
                      #25
                      use ifaith to save blobs for 5.0.1 and create a custom ipsw with the same tool. place in dfu, then connect to itunes and when you press restore, hold shift to locate your custom ipsw for restoring 5.0.1 then apply jb with redsn0w 0.9.10.
                      job done
                      • cablefreejunkie
                        • 1717
                        #26
                        job done
                        quick update,,plugged into i tunes and it recognised dfu,so did a full restore to ios 5 again then re broke wth redsnow,working fine at the moment,,i saved my shsh tonight using i faith then tried to build a custom ipsw,it went all the way and then at the end after looking like all was well i got an error saying the ipsw was not correct or something along those lines,i let ifaith find the ipsw so not sure whats wrong there
                        • fijiman
                          • Oct 2010
                          • 976
                          #27
                          Why are you building a custom IPSW...? if your jailbroken...?
                          • fijiman
                            • Oct 2010
                            • 976
                            #28
                            When using the latest iFaith...and you want to create a custom firmware I would use Sn0wbreeze...as both are made by the same guy... iH8sn0w
                            • cablefreejunkie
                              • 1717
                              #29
                              im getting confused slightly fijiman
                              i was building the ipsw incase my jailbreak goes tits up and apple stops signing 5.0.1
                              • fijiman
                                • Oct 2010
                                • 976
                                #30
                                No mate...you can still download any firmware for any iDevice any time....the problem is installing the firmware if it's NOT being signed by Apple.... That's why we save our SHSH blobs to fool iTunes into thinking firmware being installed is current(but in reality it's not)
