jailbreak for 3.1.3
  • lupu_sandu
    V.I.P. Master of the IMMO
    • 7914
    #46
    Spirit have been released. Tested on iPhone 3GS fw. 3.1.3
    4C7570755F73616E64755F696D6D6F5F736F6C7574696F6E73
    • m9g
      • 704
      #47
      Can anyone confirm this actually works on 3g 3.1.3 with baseband 05.12.01 please
      M9G
      DONT FORGET TO CLICK THE THANKS BUTTON IN THE BOTTOM LEFT CORNER OF THE POST IF ANYONE HELPED YOU
      • southbrook
        • 97
        #48
        Can confirm it works
        3gs 3.1.3 new boot.
        PSN id RISSIEN
        • m9g
          • 704
          #49
          thanks appreciated
          • owenb
            • 703
            #50
            works on 3gs new straight from factory with new bootroom and 7e18
            • aftermath
              • 4345
              #51
              Class..........
              works a treat
              • skegsagypsy
                • Aug 2009
                • 1230
                #52
                Brilliant, thanks a lot much appreciated.
                Ok just done my phone brand new 3gs 3.1.3 worked flawlessly, now what though as I haven't a clue , does this men I cn download apps free and if so where from....sorry if its a daft question.
                'If you are neutral in situations of injustice, you have chosen the side of the oppressor. If an elephant has its foot on the tail of a mouse and you say that you are neutral, the mouse will not appreciate your neutrality.'
                -Bishop Desmond Tutu
                • southbrook
                  • 97
                  #53
                  just torrent them...... easier to get ones that are .ipa files, I am new to this myself and have downloaded ones that come in a payload folder but not worked them out yet. Also when you jailbroke it - open cydia and search for "Appsync" and install it. This allows you to install cracked apps in itunes. Simply drag the .ipa file into itunes and sync your device. Voila!!
                  ( just got latest TOMTOM and its sweet )
                  PSN id RISSIEN
                  • loncell
                    • 625
                    #54
                    is this ok for a ipod touch 3.1.2 8GB ?
                    • southbrook
                      • 97
                      #55
                      from spirits website........
                      Requirements
                      Any iPad, iPhone, or iPod touch on firmware 3.1.2, 3.1.3, or 3.2.
                      An activated device: one not stuck on the Connect to iTunes or Emergency Call screen.
                      Any version of iTunes 9 (including 9.1.1).
                      Syncing with iTunes before trying this highly recommended.
                      Hope this helps m8
                      PSN id RISSIEN
                      • southbrook
                        • 97
                        #56
                        One other thing guys....... spirit will remove photos when you use it so back these up before you jailbreak it
                        PSN id RISSIEN
                        • stephen_falken
                          • Aug 2009
                          • 17
                          #57
                          Can confirm it worked on the missus 3GS with the following spec: (details from f0recast)
                          serial: 8101xxxxxNP
                          baseband: 05.12.01
                          bootloader: 6.4
                          model: MC131
                          jailbreakable: only if shsh is saved
                          unlockable: NO
                          tethered: Maybe
                          Best of luck folks!
                          Regards
                          • aftermath
                            • 4345
                            #58
                            run in windows 95 compatible mode
                            should see cydia app on phone when done
                            and all my apps still intact
                            you need to get installous now
                            in cydia click manager at the bottom
                            click sources
                            click edit at the top
                            click add
                            a url box will pop up add this
                            cydia.hackulo.us
                            also add this
                            and this
                            apt.ripdev.com/
                            box says who are you
                            user
                            hacker
                            developer
                            which one ?
                            choose user
                            Hackulous Tutorial: How to get Free iPhone Apps | iPhoneSpies
                            install hackulous ?
                            http://www.iphonespies.com/iphone-ne...e-iphone-apps/ same as thaT
                            GO BACK INTO CYDIA
                            then searcdh for appsync
                            3.1
                            then install ?
                            on installous go into setting and turn on itunes sync
                            thern go into installous ?
                            yep and download what ya want now
                            anything on apptrackr home
                            __________________
                            • fms267
                              • 43
                              #59
                              sorry of topic but payload folder is an ipa file that windows dosnt see correcty
                              you need to goto control panel
                              select folder options
                              uncheck hide extensions for know file types
                              then right click rename then delete the .zip at the end of the name
                              then windows should see it as an .ipa
                              • lupu_sandu
                                • 7914
                                #60
                                Spirit have been updated:
                                Other Stuff
                                • Update (May 3): I've updated the jailbreak tool. It no longer deletes photos (sorry!) and should resolve the issue with error code c0000005. (If you still get that error with the new version, try setting compatibility mode to Windows 95.)
                                Spirit
