iPhone loop, unable to boot?
  • Crispie
    • Jul 2010
    • 5
    Hey guys.
    I have expirenced that my iPhone 3GS while charging was stuck at the boot screen (the "Appel") The phone was warm, and i could not reset it or shut it off.
    Backing up at this point is history, and the solution is not as usually to put in into DFU mode (or yes it is, but it will not work doing it the usual way..). You have to hold the home and the power button pressed, an do not release ANY of the buttons, even after the iPhone switces back on, after a little while (up to 30 seconds) you will get the "Connect to itunes" symbol.. Now you can start re-installing the firmware through iTunes.
    And remember to make backups once in a while... (bitter experince...)
  • LaiWongBao
    • 55
    If you have jailbreaked before, you can hold SHIFT when doing the restore and restore to any firmware you want.
    Because your SHSH files should be saved on Cydia.
    Here's the link where you can download the firmwares.
    iPod, iPhone and iPad Firmware Download
    • mariank32
      • May 2010
      • 7
      OK
      [Quote = LaiWongBao ; 733259 ] Jeśli jailbreaked przed , można trzymać SHIFT podczas wykonywania przywracania i przywr?cić do każdego firmware chcesz.
      Ponieważ SHSH pliki powinny być zapisane na Cydia.
      Oto link gdzie można pobrać firmware .
      iPod, iPhone i IPAD Firmware Download[/ Quote]
      OK. Thanks
